homemade press brake need advice
发表于 2021-8-31 22:32:52 | 显示全部楼层 |阅读模式
Got the idea to make an attatchment for the press I am also making from offroadswag. I have a piece of 1" thick by I think 4" wide piece of steel that I plan on grinding an angle into but am unsure of what angle to use. I'm thinking 45 since I'm gonna be using some 1/4" 1x1 angle to press the metal into.93 Bobcat 225GMillerMatic 135HF Tig 91811
Reply:It would be 45 deg each side or 90 deg included. Actually a little bit steeper than that since there's spring back when you bend something.Millermatic 252XMT 304'sDynasty 280DXHypertherm PowerMax 1250Miller Trailblazer 302 EFIOptima PulserXR feeder and XR Edge gun and more athttp://members.dslextreme.com/users/waynecook/index.htm
Reply:When i build mine I'm going to weld square bar to the "blade" so it can be replaced when it deforms. I think it will be easier than grinding it down.GravelThe difference between theory and practice is that in theory there is no difference.
Reply:If you are thinking about pressing into the angle you will not get a 90 degree bend. What you want to do is use 2 angles welded on a base plate (looks like a "W" upside down) and shim the two outside legs of the angles to make the inside angle less then 90.  Press in between them for your 90DIY CNC Plasma table USB BOB Price THCHypertherm 65Everlast PowerTig 255 EXTMiler 180 Mig13" metal latheMill/ DrillECT, ECT,
Reply:^^^^ good advice ^^^^GravelThe difference between theory and practice is that in theory there is no difference.
Reply:thanks for the input. I'm a little ways from that step. Havent cut my channel for the press frame yet but will look back on this thread for you advice acourtjester.93 Bobcat 225GMillerMatic 135HF Tig 91811
Reply:I have a HF 20 ton press that I made a metal brake for. I did 1/4''x6'' flat no problem. I also added a gate valve handle to the pressure  release and it is easier and a time saver.
Reply:Here is the one I just built.  Its only 6". And the first 2 bends I made with it in 2" x 1/4.  I am thinking of building a 4 ft press brake that will do 1/4".Miller XMT 304 cc/cvMiller 12RC w/ 15ft Tweco #4 GunMiller 30A SpoolgunCustom Thermal Arc TA 10/270 Generator "Thermal Star"Smith oxy/acet-propane with weld, cut & rosebud tipsAnd of course grinders, chop saws, hand tools
Reply:Originally Posted by acourtjesterIf you are thinking about pressing into the angle you will not get a 90 degree bend. What you want to do is use 2 angles welded on a base plate (looks like a "W" upside down) and shim the two outside legs of the angles to make the inside angle less then 90.  Press in between them for your 90
GMT+8, 2025-12-31 09:10 , Processed in 0.104309 second(s), 18 queries .
