Gate nearing completion
发表于 2021-8-31 22:32:50 | 显示全部楼层 |阅读模式
Hello all,Here are a few photos of a Pivoting-sliding cantilver gate that I have built for my house. The two sections are 13' 4" each and the cantilever opening is 10', basic structure is 6x6x3/8 pivot post bolted to a rebar cage embeded in 24" dia 10' deep hole filled with concrete, other posts are 5x5x3/16 the gate is built of 2x4 retangular and 1.25 square tube with A606 corten woven between the pickets. I still have to design  install the atomatic openers on the slider and pivot sections complete the end post( brown in the photos ), drypack the baseplates and install a 28' x 30' aluminum cover over the concrete pad behind the gate, I live in sunny Phoenix Az so shade is a necessity!Thanks for lookingFillister Attached ImagesLast edited by zapster; 12-26-2013 at 03:42 PM.
Reply:Very unusual and stunningly beautiful. Wow...POVERTY...is the Mother of InventionMillermatic 211Millermatic 140Miller Thunderbolt XLArcOne 100STS inverter w/TIGThermal Dynamics 38XL Victor Oxy/AcetyleneJancy Slugger Holemaker IIJet 5x6 BandsawNever enough time & sleep.
Reply:very nice design. what kind of hinges are you using?i.u.o.e. # 15queens, ny and sunny fla
Reply:wow, i love the basket weave look. that is very cool, looks like alot of work making all those panelsMiller Syncrowave 210 w/CK FlexLoc 150  3/6/14ESAB PCM 1125 Plasma CutterAtlas 12x36 LatheACER 9x42 3hp millHarig 612 Surface GrinderDRINK Machine              welding&fabrication
Reply:Thank you for the complement SMC
Reply:Chevydyl,I had the local metal roofing company (the only place I could get corten) run full sheets through their slitter at $5.00 per pop.
Reply:Nicely done - fits the surroundings very well Thanks for posting this, I was unaware of A606-4 type steel and its uses. Now that I've researched it, based on your listing, I'm thinking about where I should use it as well.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Docwelder,Just some from a left over project really nothing more than 2 7/6 od DOM countered bored for a radial bearing with a 1" id. A 1" od 3/4 id sleeve drops through the bearing assembly and a 3/4 bolt retains the barrel assembly to the hinge pad.
Reply:Originally Posted by tackitVery beautiful gate.  Just wondering if it might get so hot during the summer it can burn folks that may brush up against it.
Reply:Originally Posted by fillisterDocwelder,Just some from a left over project really nothing more than 2 7/6 od DOM countered bored for a radial bearing with a 1" id. A 1" od 3/4 id sleeve drops through the bearing assembly and a 3/4 bolt retains the barrel assembly to the hinge pad.
Reply:looks really great. I have a couple of questions?1. the A606-4 type steel: will it rust and drip on to the painted metal?2. what is the benefit of making the gate sliding and hinged? why not just make the gate split in the middle and have it open from a hinged left and right.3. how did you get a 10' deep hole dug?
Reply:Originally Posted by AluminumWelderlooks really great. I have a couple of questions?1. the A606-4 type steel: will it rust and drip on to the painted metal?2. what is the benefit of making the gate sliding and hinged? why not just make the gate split in the middle and have it open from a hinged left and right.3. how did you get a 10' deep hole dug?
Reply:Originally Posted by MinnesotaDaveNicely done - fits the surroundings very well Thanks for posting this, I was unaware of A606-4 type steel and its uses. Now that I've researched it, based on your listing, I'm thinking about where I should use it as well.
Reply:I just finished up two 175' guard rails on a bridge for the U.S Forest Service / U.S. Dept Of Agri. all 8" Corten channel iron. Stuff developes a layer of oxidation that doesn't require any protective covering, was told USS Corp has a patent on it.
Reply:I've been in the gate business for over 25yrs and that is a very unique design. Thanks for sharing and keep up the good work!!
Reply:Love the gate.  And I really like the idea of a custom made slide gate operator mounted on the swing/master gate.  I assume you're not going to have the swing operated because its use will be occasional?Llife is good
Reply:Originally Posted by wroughtn_harvLove the gate.  And I really like the idea of a custom made slide gate operator mounted on the swing/master gate.  I assume you're not going to have the swing operated because its use will be occasional?L
Reply:Originally Posted by fillisterBoth the Slider and swing will have operators when completed, I'm just an automation nut and besides the old yellow truck deserves its own remote control when it comes back from the steel yard. The gate has taken some time off as I have started to work on a press break attachment for my 50 ton hydraulic press, thought the motor and gear box mounts for the gate should be bent.Thanks for complements I spent an awful lot of design time on the cantilever system.
Reply:The design incredibly fantastic! That's a lot of work. Well done.PlasmaCam CNC cutterLathe and Band SawClamps
GMT+8, 2025-12-31 09:07 , Processed in 0.226068 second(s), 18 queries .
