Bed Frame Welding Cart
发表于 2021-8-31 22:32:50 | 显示全部楼层 |阅读模式
Someone left a treasure by the dumpster behind the shop, a bed frame. Not just any bed frame, but one from a hospital bed.Much beefier than the usual frames that I've run across.I decided to build a cart for my Miller 211 using as much of the frame as I could.Here's the frame broken down.Here's the cart welded up with out the lead hangers in it's unpainted state. Sorry for the lack of photos while I was building it, but you wouldn't want to see my crappy welds.Here's the frame getting a coat of Rustoleum Sail Blue after being sanded and primed.Here's the completed cart with lead hangers but with out the filing cabinet in the bottom.Continued next post
Reply:I added a 3 drawer filing cabinet I found at a thrift store for storing wire and tools.Here's a couple of views of the cart loaded up. I built it wide enough to hold two bottles, 75/25 and argon for aluminum.Here's all that was left of the bed frame, still some usable pieces for other projects.I also used some flat bar,angle iron, channel and expanded metal in addition to the frame.Last edited by CamW; 04-11-2014 at 02:44 AM.
Reply:Looks spectacular!   Nicely done. I really like the filing cabinet addition you did to yours.  Looks sharp!Last edited by SuperArc; 04-11-2014 at 04:37 AM.Lincoln Power Mig 216Lincoln AC/DC-225/125Miller  625 X-Treme PlasmaMiller 211 Forney 95FI-A 301HF 91110Victor Journeyman O/PMilwaukee DaytonMakita  Baileigh NRA Life Member
Reply:w; nice re-use of an old bed frame. i use to grab those frames whenever i saw them laying around.i.u.o.e. # 15queens, ny and sunny fla
Reply:I like it!  I also pick up bed frames when they are out by the curbs, have made many things from them.  The steel is free for the taking and very useful for projects.  Bob
Reply:Good Job - Safety blue is a close match alsoThe main thing is not to panic or get excited Bobcat 250, X-Treme 12VS,  MM211Meltabo, Milwaukee,Porter Cable,Dewalt,MakitaVictor O/A, Ingersoll-RandEvolution Rage2, 40 amp PlasmaLincoln 225 AC/DC
Reply:Talk about repurposing, nice job on the cart Sent from my iPhone using TapatalkWill   Supports Autism Awareness                            My ToysBobCat 225 PLusMillermatic 130Miller Spectrum 300 CutmateEverlast Power Tig 185 Micro April is Autism Month .
Reply:Great lookin project,!!! And you did your part in saving the planet,,,I try to save the planet every time I go to dump out our trash trailer at transfer station. You cannot believe what I have picked up including all the bed frames I come across as most of them are 1 1/2" X 1 1/2" and the material is great for most projects around the house. Nice job!
Reply:Very nicely done.  Great use of material!
Reply:Ever notice that whenever you weld on bed frame material....They all smell the same?Yuck....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Pretty sweet idea with the filing cabinet. Sent from my iPhone using TapatalkLincoln Pro Mig 180HF Stick/Tig Inverter WelderLincoln AC225s
Reply:Great conversionWhat happened to the drive motors??DIY CNC Plasma table USB BOB Price THCHypertherm 65Everlast PowerTig 255 EXTMiler 180 Mig13" metal latheMill/ DrillECT, ECT,
Reply:How can you have crappy welds with a 211?  Looks great!
Reply:Looks nice. I have quite a few old bed frames laying around. I always find some use for them.
Reply:That's a great cart made from reused metal!
Reply:The brown epoxy paint smelled up the shop pretty bad, and its pretty tough stuff. I wire wheeled off what I could, bead blasting with aluminum oxide didn't touch it.I still have the drive motors and control box, one motor works one is dead. I'm trying to figure out what to make with it.Does anyone need a store bought cart? I'll let it go cheap!
Reply:Very nice job. I like the use of the filing cabinet for storage..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:I welded some bed frame angle once. It's not normal steel, it cracked n stuf. Did you notice any of this on your cart?Welding/Fab Pics: www.UtahWeld.com
Reply:You coulda traded that at Jaco beach  I know gurlz that can earn $200 an hour with one of those.Bubble gumTooth pixDuct tapeBlack glueGBMF hammerScrew gun --bad battery (see above)
Reply:That is awesome, great recycling of materials.
Reply:That's got to be one of if not the best "bed frame repurposing" projects I've ever seen.  Love the design and especially the tank restraint system hooks.  Great job!!MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Great salvage of the materials. That's a beautiful cart there.PlasmaCam CNC cutterLathe and Band SawClamps
Reply:i picked up one of those bed frames today.  i already have store bought carts so i'm not sure what to make out of mine.  i'm the most uncreative person i know .great job on your cart
GMT+8, 2025-12-31 09:08 , Processed in 0.106285 second(s), 18 queries .
