Here it is another welding table
发表于 2021-8-31 22:32:50 | 显示全部楼层 |阅读模式
found this frame outside the local tractor supply. actually found two, they are frames that mowers are shipped on I am guessing. cut one apart to make the rest of this table. basically just put some legs on it. yes I know it isn't the thickest tube steel but it does seem plenty stable. so here it is.Lincoln 225 ac (my first machine)farmhand 115vac 70amp mig/fc toymiller aead 200le (my main machine)
Reply:Looks huge, gonna be able to move in the garage after building it?
Reply:I think im gonna put some kind of casters on itLincoln 225 ac (my first machine)farmhand 115vac 70amp mig/fc toymiller aead 200le (my main machine)
Reply:Damnit. The chopsaw . The guard says " Hitachi". The Handle suggests Jet..... ATD ? I can usually ID tools from the window of a 747(pre-no-fly list days).What is that saw ?Bubble gumTooth pixDuct tapeBlack glueGBMF hammerScrew gun --bad battery (see above)
Reply:it is a performax from menardsLincoln 225 ac (my first machine)farmhand 115vac 70amp mig/fc toymiller aead 200le (my main machine)
GMT+8, 2025-12-31 09:09 , Processed in 0.075430 second(s), 18 queries .
