nutsert install tool
发表于 2021-8-31 22:32:46 | 显示全部楼层 |阅读模式
HiHere is a tool I built some time ago for installing nutsert/ rivet nuts in projects.Only one handle needs to be made even though I show two.The handle is made from 1” round stock drilled and taped with ½” 20 thread about 2” long.  With a ½” round stock about 6” long welded to the 1” round stock.Using two ½” 20 thread bolts center drill them out to the nutsert size you want. Cut one short about ½” long (threaded part).To use install the size ½” bolts in the handle for the nutsert you want to install with the short bolt in the lower end.  Install a washer on the bolt being used and install that into the completed handle. And install the nutsert on the exposed bolt end.  Install the nutsert into the project now turn the top ½” bolt CCW.  This pulls out the bolt and this will start the collapsing of the nutsert continue until the nutsert is completely tight in the project.  Turn the top ½” blot CW and then remove the tool from the nutsert.  Install complete.The washer allows the ½” bolt to be turned without the center through bolt from turning out of the nutsert. Attached Images
Reply:Very nicely done. Beats the daylights out of my flat bar with bolt and washers that will occassionally let the nutsert turn before it starts compressing enough to hold to finish the job.Would love to have one of those $1,200 air powered reversible driver kits some day. MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Are you backing out the 1/2" bolt to draw up the nutsert?I offer three choices: Good, Fast, & Cheap. You may pick two.Hobart AC/DC StikMate LXHarbor Freight AD HoodHarbor Freight Industrial Chop SawDeVilbis 20 Gallon, 5 HP Compressor
Reply:That's how I read it.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Yes sir but be sure you use a washer between the 1/2" top bolt and the inner bolt.have funTom
Reply:That tool is well done!Matt
GMT+8, 2025-12-31 09:07 , Processed in 0.179268 second(s), 18 queries .
