anyone hear of KG o/a cutting torches?
发表于 2021-8-31 22:32:31 | 显示全部楼层 |阅读模式
Any on hear of them or have one Says K-G equipment company.  f636090 and b-a on bottom by hose hookups old unit.   Know where to get tips?    Weird tip too its like a victor but threaded at top.  Tip threads into head then you put the nut over it the tip.
Reply:It'd make a nice conversation piece.You won't find tips but if you just wanted a challenge you could surely make some. There is a guy on this site that rebuilds regs and torches as I recall.Bubble gumTooth pixDuct tapeBlack glueGBMF hammerScrew gun --bad battery (see above)
Reply:Just for future people searching these tips fit and are made by goss.http://www.toolfetch.com/goss-go-146...ducts-121.html
Reply:From a 1947 trade journal: For more than 30 years, K-G Welding and Cutting Company has manufactured welding and cutting torches and ... Now, as a subsidiary of Air Products, Incorporated ...Looks like the name was changed to K-G Equipment Co. in the 50's. American Torch Tip makes tips for Air Products (KG) torches."USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:I have a K-G combination torch showing manufactured in Allentown Pa (home of Air Products i think)  but has cutting attachment only.Older ads for K-G show New York as home town. It is a very nice, compact torch.probably made after WW2.
Reply:If you search through the old welding related books and trade journals that Google has scanned (out of copyright - full text), there's all kinds of fascinating stuff from the 1920's and before.  The old ads are a hoot to read.  Some of the old companies disappeared, some were absorbed by larger companies and others still prosper."USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:Post a pic of your torch tip SHOWING THE BASE as tip styles vary considerably.You might be able to find tips on Ebay or a tip conversion adapter.
GMT+8, 2025-12-31 07:28 , Processed in 0.093952 second(s), 18 queries .
