Honu SW: MagDrill SOF
发表于 2021-8-31 22:32:23 | 显示全部楼层 |阅读模式
Honu SW MagDrill SOF.  Custom design/build for local client's Jancy Slugger Holemaker II MagDrill.  Accommodates annular cutters, twist drills, and hole saw applications for steel, aluminum, wood, acrylics, etc.  Planar surfaces, 1/2" A36 HRS.  Round members, 1020 DOM tubing, TIG'd to 1018 CRS bases.  SHCS black oxide fasteners.  Fabricated and TIG'd Tee with T-slots provide vertical translation and rotation of work surface relative to MagDrill.  Work surface removable for attacking larger sized work pieces.   Finished with 1-stage, matte black powder coating courtesy of FigureFinishing, LLC.Designed & Built in USA. Attached Images"Discovery is to see what everybody else has seen, and to think what nobody else has thought" - Albert Szent-Gyorgyi
Reply:That is awesome, pretty soon you will be going into mass production with these things. The photography is excellent and the added touch of the cutters sitting on it is really nice. Seeing your creations and all of the mag drill posts lately is the main reason I'm buying myself a new toy by the end of the monthTOO MANY TOOLS & NO MORE SPACE
Reply:That looks really nice. I like the black powder coat with the natural steel - looks great like that.The T fitting for adjustable height and tilt is a great touch - nicely done!Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Nice work Kai! I wish I had time to make crap half as nice as this."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:Excellent Job. Richey
Reply:Great job Kai. VERY professional.
Reply:Appreciate the looks and "+"s.   The next revision has a few operational add-ons.  Note:  translational stability for this model, in the event of electrical power disruption, is controlled via the Slugger II's integrated D-hooks (thru magnetic base) and complementary ratchet strap.  The strap wraps around the Honu's IP (interface plate) for lock-down.  Flow flows from function. Last edited by 7A749; 04-22-2014 at 07:35 AM.Reason: OP req."Discovery is to see what everybody else has seen, and to think what nobody else has thought" - Albert Szent-Gyorgyi
GMT+8, 2025-12-31 09:09 , Processed in 0.104482 second(s), 18 queries .
