Opinion on new welder purchase - Lincoln power mig 200
发表于 2021-8-31 22:32:19 | 显示全部楼层 |阅读模式
I havent welded seriously in years. I took a class in high school for a couple years and I have stick welded a few times, but I came across this welder and thought I would get it for my project.First the project: Im building a 1991 F250 4x4 truck. I am welding 1/4" plate to the frame for various supports and I am also wleding 1/4" plate on the axle housings and tubes for trussing strength. Now the Wlder: I came across this Lincoln power mig 200 this guy had. It has aonly been used a couple of times (looks really clean). It came with two full tanks of argon/CO2 mix, one tank is about 5ft tall and the other tank is about 2ft tall. It also came with an autodarkening helmet, which I have never used to this point. I got everything for $800. I have tried to look up information on this welder online, but lincoln doesnt have anything on their website about it. My questions are:1) Was this a good deal2) Is this welder suitable for my project above3) Is this a descent welder? If so, why cant I find anything on it anywhere?Thanks for the input and helping us newbs learn about welding.
Reply:It sounds like a good deal considering the 2 cylinders you got with it.Millermatic Passport PlusMillermatic 200Millermatic 350P with PythonXMT 304 /w S-64 feeder and 12RCDynasty 300 DXVictor O/APremier Power Welder for my trail junk.
Reply:Heres a link to a manual on the Lincoln Power Mig 200 and another to an article on it. Sounds like a good deal with the two tanks. Should be more than enough power to weld what you described and then some. Have fun with it.http://content.lincolnelectric.com/p...r/im/im693.pdfhttp://www.memagazine.org/backissues...m/welddom.htmlLast edited by WolfmanJack13; 06-04-2007 at 03:04 PM.Latest Toys Miller 180 Mig and Elite Mask!!Wright Welder 225ACShop OutFitters 20/20 Bending SystemHypertherm 380 Plasma30 Years of Sparking (Electrical & Welding)
Reply:Thanks for the feedback. I was wrong about the cylinder sizes. 1 cylinder is about 5'6" and the other is almost 4' tall. These are full of the 75/25 mix. hanks for the manual link, that will definitely come in handy. Did Lincoln quit making these or something? I couldnt find anything on their website. If they did stop making these I wonder why?
Reply:I think that´s a pretty awesome price even for the machine itself...my 175 was at 599 at lowes...but 200 its way better way betterReallly don´t know if they stopped making them...maybe cause the proximity to the 250 version? really don´t know but its an awesome machine...good luck with itMy Babies: HF Drill pressHF Pipe Bender3   4.5" Black and Decker angle grindersLincoln Electric PROMIG 175that´s it!
Reply:Originally Posted by broke33couldnt find anything on their website. If they did stop making these I wonder why?
Reply:I have (2) PowerMIG 200's and absolutely love them. Lincoln still makes the comparable welder but it's now called the PowerMIG 215.Good luck with the project and be sure to post some pics of it on the "Projects" section.- PaulLast edited by ZTFab; 06-04-2007 at 09:32 PM.http://all-a-cart.comWelding Cart Kits and accessories
Reply:Only negative I've heard on the PM 200 is the output on a few of the taps is a little on the hot side. Also heard  , this issue was cured on the PM 215.
Reply:It looks like a great machine for auto body and frame/chassis work. What accessories should I consider buying for this machine? What would I need to weld aluminum? I would like to do some aluminum diamond plate welding (1/4" stuff) and then just the chassis/frame stuff. Is it possible to weld patch panels on the body with this welder or is it too much welder for that? Is there any special wire I should use for the sheet metal patch panels and the aluminum? Thanks again for the info
GMT+8, 2025-12-31 09:10 , Processed in 0.084012 second(s), 18 queries .
