AC-225 leads
发表于 2021-8-31 22:32:19 | 显示全部楼层 |阅读模式
I have an ac-225 with the stock leads on it. I'd like to get 25' leads to replace them with. Should I use the same size wire, or go larger? The leads on it now say 5awg on them.Lincoln AC-225Airco Oxy/Acetylene14" chop sawOld tired bench grinder
Reply:Check out the thread frather down the list( should apear on the same thread page) labled AC-225 cable length.  I think you'll find the answer there.  Sorry, I guess its in the General Questions topic, and its called AC-225 cables.  If you do a search you can find it.  Sorry io don't know how to link.Last edited by fordtrucks; 06-07-2007 at 12:01 PM.
Reply:Put a set of Tweco quick connects on it and you can run miles of cable. Just make sure it is not coiled, AC does not play well with coils.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
GMT+8, 2025-12-31 09:09 , Processed in 0.115163 second(s), 18 queries .
