Duty cycle on s-32p 12 suitcase
发表于 2021-8-31 22:31:59 | 显示全部楼层 |阅读模式
Hi Guys,I hurt my back this week and I am totally immobile, so while sitting here bored out of my mind I actually read the owners manual on my suitcase.  I have a duty cycle question for the experts.  On page 1 of the manual (page 7 of pdf document) it lists the duty cycle of the s-32p 8 as 500 amps 100% duty cycle and the s-32p 12 at 260amps 60% duty cycle.  Why would the smaller version have a higher duty cycle?  It doesn't really matter for me because 260 amps at 60% is good enough for my welder/generator, but why the discrepancy?thanksfarmer2http://www.millerwelds.com/om/o1545j_mil.pdf
Reply:The 32-8 doesn't have a contacter or a gas solenoid. The contacter on the 32-12 must have a lower amprating. I have never seen an 8 in person or on Ebay.Miller xmt304,  Miller S22 p12, Miier Maxstar SD, Miller 252 w 30A, Miller super32p12, Lincoln Ranger 9, Thermal Arc 181I with spoolgun, Hypertherm 10000 ,Smith torches. Esab 161lts miniarc.
Reply:I've had my 32p for 15 years and didn't know what the amps were on it. I did when I got it. Never missed a beat. I was looking at the others but haven't studied up on them. If this one dies for some reason I'd buy another one just like it. The only difference is I'd get the blue case. Unless one of the newer units has a pulse mode on it. That would be worth it...I guess. I see the new units are around $1800 and up. Pricy.Arcon Workhorse 300MSPowcon 400SMTPowcon SM400 x 2Powcon SM3001968 SA200 Redface1978 SA250 DieselMiller Super 32P FeederPre 1927 American 14" High Duty LatheK&T Milwaukee 2H Horizontal MillBryan
Reply:Originally Posted by M J DThe 32-8 doesn't have a contacter or a gas solenoid. The contacter on the 32-12 must have a lower amprating. I have never seen an 8 in person or on Ebay.
Reply:Without a contactor your wire is always HOT .  As far as duty cycle usally whatever gun you are using would almost always be the weak link. I really cant see the feeder being able to run at 500 amps anyway since it only has a 2-0 cable feeding it .Miller xmt304,  Miller S22 p12, Miier Maxstar SD, Miller 252 w 30A, Miller super32p12, Lincoln Ranger 9, Thermal Arc 181I with spoolgun, Hypertherm 10000 ,Smith torches. Esab 161lts miniarc.
Reply:Ok thats what I thought on the contactor (mine has it).  good point on the cable.
Reply:I'm thinking 500 amps and .045 wire. Hell yeah. o...and 150 amp gun. Farmer2 yes that's what the contactor does. A switch for when you lay the gun down the wire isn't live like a stick welder.Arcon Workhorse 300MSPowcon 400SMTPowcon SM400 x 2Powcon SM3001968 SA200 Redface1978 SA250 DieselMiller Super 32P FeederPre 1927 American 14" High Duty LatheK&T Milwaukee 2H Horizontal MillBryan
Reply:I forgot to ask. What did you do to your back? Fighting Ninjas, rescuing orphans? or like me slipped on the ice. I busted my donkey the other day. One of those deals it took 30-40 seconds to actually hit the ground. I think I hurt myself worse doing the catch my balance dance long before hitting the ground. Hope you get better quick. It's no fun being laid up.Arcon Workhorse 300MSPowcon 400SMTPowcon SM400 x 2Powcon SM3001968 SA200 Redface1978 SA250 DieselMiller Super 32P FeederPre 1927 American 14" High Duty LatheK&T Milwaukee 2H Horizontal MillBryan
Reply:Originally Posted by blawlessI forgot to ask. What did you do to your back? Fighting Ninjas, rescuing orphans? or like me slipped on the ice. I busted my donkey the other day. One of those deals it took 30-40 seconds to actually hit the ground. I think I hurt myself worse doing the catch my balance dance long before hitting the ground. Hope you get better quick. It's no fun being laid up.
Reply:Farmers2, it has happened to me  3 times. The first time like you said needed help getting up. After 3-4 days got better, from what doc said Age(52 ) and weak back muscles. If standing you can not see your belt buckle,start walking and exercise and limit intake. I am 5' 9" and 190 lbs and need to lose some weight.Rest  and take care
Reply:Originally Posted by farmer2I wish I knew bent down to move an atv ramp, and before I even got to it "bam" down I went.  It took me 30minutes to crawl to the house (50ft).  I ended up in the hospital because I was having uncontrolled spasms.  I still can't walk.  I had a cat scan and the doctor thinks its muscle related.  I have an MRI on thursday, so I will know then.  Thanks for the well wishes.farmer2
Reply:Originally Posted by 7A749Damn Dave. I was exercising regularly a few years ago & my back still hurt like hell.I have nerve damage tho. Even when I was 50 pounds lighter in 2006, I had just as much pain as I do now.Gotta be real careful now. Some days are ok, some are hell.
GMT+8, 2025-12-31 07:28 , Processed in 0.200118 second(s), 18 queries .
