Friday at the shop........
发表于 2021-8-31 22:31:59 | 显示全部楼层 |阅读模式
You guys are probably getting real tired of the Handicap Lifts ( Me too)  but they bring in so much money I cant turn the account away....This was this mornings stuff. The New Mixer is working great......I'm still playing with inlet pressures to change the % of helium Im getting since this mixer was made for Argon/Hydrogen   the conversion chart Smiths sent will only work for 50% and I need a bit more at times so I'm using less pressure on the Argon inlet than the Helium side.....That completely changes the chart so it's kinda seat of the pants stuff......Still really cool even though one of my new Victor regulators leaked right out of the box.......  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:I can't find it right now but at one time I found a parts break down for one of those. I'm pretty sure there's a balance regulator inside the mixer that guarantee's both gases go to the orfices at the same pressure. Thus changing the input pressure on one of the feed gases shouldn't affect the output that very much.  I researched this a good while back just to see how they worked and compare them to my home made mixer. That was the only real difference I found when compared to my mixer. It's also the main thing I have to keep a eye on when using my mixer. I have to make sure the inputs are set to as close to the same pressure as I can to make sure I get the right mixture.Millermatic 252XMT 304'sDynasty 280DXHypertherm PowerMax 1250Miller Trailblazer 302 EFIOptima PulserXR feeder and XR Edge gun and more athttp://members.dslextreme.com/users/waynecook/index.htm
Reply:Maybe that thing can be "rejetted" to give a better range.  I remember Jay saying he'd contacted Smith about it when he bought it and they gave him the fudge factors."USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:little off topic but I always liked that BT-18 chassis nice and clean, Kosman  built some nice stuff, sorry to go off topic.
Reply:What would a mix of argon/hydrogen be used for?
Reply:I think he's mixing argon and helium, helium helps weld thick aluminum with less amps. Hydrogen is very flammable... Don't want to mix that with anything near a fire or arc or a spark
Reply:BC's got to be the only one who buys TIG rod in 50 lb. boxes!
Reply:Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:Argon/Hydrogen mixtures are used for high speed mechanized TIG welding on stainless steels, nickel-copper and other nickel based alloys.
Reply:Originally Posted by 4956Argon/Hydrogen mixtures are used for high speed mechanized TIG welding on stainless steels, nickel-copper and other nickel based alloys.
Reply:Your shop is cool BC Nice doggies too - had a really great springer when I was a kid Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Yeah Argon/Helium........The mixer was designed for Argon/Hydrogen.......Used with a conversion table from Smiths it works great.....  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:Originally Posted by 7A749I just went back & looked at his PM. It was Argon and Oxygen he was originally using with that mixer for spray arc.Thanks for the clarification
Reply:If my house and shop were connected I don't know if I would ever get anything done. Or maybe I would just move my bed to the shop. I like the setup.Arcon Workhorse 300MSPowcon 400SMTPowcon SM400 x 2Powcon SM3001968 SA200 Redface1978 SA250 DieselMiller Super 32P FeederPre 1927 American 14" High Duty LatheK&T Milwaukee 2H Horizontal MillBryan
Reply:It has its advantages......Also some down falls...Guys just show up after I'm closed expecting me to weld their part because I live here and Its not that much trouble.....They are the ones I ask to NEVER come back.....  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:All I can say is "Wow....nice shop" I have no idea what else it is you guys are discussing.Hobart Handler 175Lincoln 225Rockwell 15-017 Drill Press
GMT+8, 2025-12-31 09:52 , Processed in 0.072596 second(s), 18 queries .
