Mixer headway
发表于 2021-8-31 22:31:57 | 显示全部楼层 |阅读模式
Getting pretty good with the Ratio but still can't figure out my Camera....  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:Interesting. I thought a lot of your stuff was DC tig. Sounds like AC to me.They do make helium analyzers typically used for dive gas. They aren't cheap though and for your use it might not matter. If you are really curious about your mix, you might be able to track down a tech diver who has one and he can read your mix. Never tried it with helium/argon. All the ones we did were all helium/ nitrogen /O2 mixes  but the units didn't read O2. We had to measure that separately from the He to give us our mix..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:What are your machine settings in that video.www.tjsperformance.comDynasty 300 DXHTP 240HTP Microcut 380Hyperthem 85JD2 Hyd Bender and HF Hyd Ring Roller all in one =(Frankenbender)Bpt. Mill/DRO4' x 8' CNC Plasma TableInstagram: tjsperformanceYT: TJS Welding and Fabrication
Reply:welfing amps is 260, Hertz 100, bal 78 soft sq wave 1/8  2% Lanthinated  std #6 cup  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:Originally Posted by DSWInteresting. I thought a lot of your stuff was DC tig. Sounds like AC to me.They do make helium analyzers typically used for dive gas. They aren't cheap though and for your use it might not matter. If you are really curious about your mix, you might be able to track down a tech diver who has one and he can read your mix. Never tried it with helium/argon. All the ones we did were all helium/ nitrogen /O2 mixes  but the units didn't read O2. We had to measure that separately from the He to give us our mix.
GMT+8, 2025-12-31 07:29 , Processed in 0.072947 second(s), 18 queries .
