1979 Miller big 40 engine issues.
发表于 2021-8-31 22:31:56 | 显示全部楼层 |阅读模式
Hey I'm using a 1979 Miller big 40 to practice pipe welding. When I put the bead in or run a grinder the machine does ok but when I hot pass fill and cap it acts like it wants to die. I changed the fuel filter and put fresh plugs and wires in it. I'm thinking it's the carburetor. Does anyone have any suggestions or maybe some troubleshooting tricks. Thanks. Sent from my HTC6500LVW using Tapatalk
Reply:Could be it could stand a carb overhaul.  May have a partially plugged main jet/passage.Does the fuel tank have a sediment bowl/valve?  Is so, check it for blockage as well.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
GMT+8, 2025-12-31 07:29 , Processed in 0.098588 second(s), 18 queries .
