Pipe Welding Stand?
发表于 2021-8-31 22:31:52 | 显示全部楼层 |阅读模式
How do you make a welding stand for pipe when welding like in 5G or 6G?Lincoln 140 Pak MIG Everlast powerarc 140 STLincoln Tombstone
Reply:I assume you are looking to build a test stand. There are many good designs here on the forum. I built mine from scraps but would eventually like to make a nicer one when I actually learn to weld pipe.http://weldingweb.com/vbb/showthread.php...ble-test-standhttp://weldingweb.com/vbb/showthread.php...Tig-Test-Standhttp://weldingweb.com/vbb/showthread.php...-6G-test-standTOO MANY TOOLS & NO MORE SPACE
Reply:Originally Posted by Chris T.I assume you are looking to build a test stand. There are many good designs here on the forum. I built mine from scraps but would eventually like to make a nicer one when I actually learn to weld pipe.http://weldingweb.com/vbb/showthread.php...ble-test-standhttp://weldingweb.com/vbb/showthread.php...Tig-Test-Standhttp://weldingweb.com/vbb/showthread.php...-6G-test-stand
Reply:I have the real deal, triangle Test Stand, all attachment and all positions , contact me if interrested
Reply:This is a test stand that I made for the school that I work at. It worked so well we put one in all 43 weld booths
GMT+8, 2025-12-31 09:44 , Processed in 0.104158 second(s), 18 queries .
