SMAW weld test for AWS certification.
发表于 2021-8-31 22:31:52 | 显示全部楼层 |阅读模式
My third semester at the local junior college.  Took my first official (AWS) weld test today for certification. It’s only 1G, 3/8-inch plate, ¼” open root with a back strap; but it was fun.  Passed the visual test, now it’s going to be sent to an X-ray testing facility.  After that it will be cut and put through a root bend and face bend test.  Fingers crossed!Next semester I will go for 3G and possibly 4G.  Cheers!GarTook this picture right after my final cover pass (1 of 2 stringers).  You can only see one stringers here, but there are two. Lincoln Electric, Power MIG 256Hypertherm Powermax 45 Miller Dynasty 280DXSmith O/A torchGenesis of a welding table
Reply:+1
Reply:Why X-ray AND bend test?... when we do our qual's we get to do either one or the other.
Reply:lookin good bro!! That's a good sign when the flux is coming off the weld like that! means the heat is within the good ballpark! nice!!
Reply:TSCGG13,That’s a fair question brother.  The place I tested at said they are using X-ray for the qualification.  I just happened to ask if when my plate comes back from X-ray, if I could bend test it and have both testing methods indicated on my cert.  The answer was yes.  I just figured it couldn’t hurt to have on my cert that my weld passed X-ray and bend testing.  Power of Blue,Thanks man, my instructor said the same thing. GarLincoln Electric, Power MIG 256Hypertherm Powermax 45 Miller Dynasty 280DXSmith O/A torchGenesis of a welding table
Reply:WELD TEST UPDATE:Plate passed the Radiographic (x-ray) and the Guided Bend Test (4.31.5).  HooYAH!GarLincoln Electric, Power MIG 256Hypertherm Powermax 45 Miller Dynasty 280DXSmith O/A torchGenesis of a welding table
Reply:good job. you'll soon be ready for the d1.1. congrats!!i.u.o.e. # 15queens, ny and sunny fla
Reply:Originally Posted by docweldergood job. you'll soon be ready for the d1.1. congrats!!
Reply:I would try to learn qn the aws 1 inch d1.1 test it will cert you to 3/16 unlimited thikness  structal steel welding. if the shop dos xray  then bend testing is not nessary
Reply:I have all WPS from Nuc Plant, if interrested I can send some, I'm retired Weld Sup, Weld Engineer , & instructor . Tested many and many of welders. Nice job
GMT+8, 2025-12-31 11:44 , Processed in 0.102737 second(s), 18 queries .
