a project for a friend
发表于 2021-8-31 22:31:51 | 显示全部楼层 |阅读模式
a friend of mine is getting into shooting USPSA matches and asked me if I could whip him up something similar to this out of aluminum,  this is designed to hold two shotgun shells stacked on top of each other and can be quickly ripped off and chucked into the shotgun. Question I have is what are those things at the ends called that hold the shells?93 Bobcat 225GMillerMatic 135HF Tig 91811
Reply:They look like spring loaded broom stick holders from the hardware store. DanManipulator Of Metal
Reply:I'm guessing you'll make about 3 version before you get the right size and tension for the holder. They do look like a broom holder.If you don't want to stand behind our Troops, feel free to stand in front of them.
GMT+8, 2025-12-31 11:43 , Processed in 0.302929 second(s), 18 queries .
