Giant sawhorse
发表于 2021-8-31 22:31:51 | 显示全部楼层 |阅读模式
Making a giant sawhorse for all our material just thought I'd share! Had to fill a bunch of gaps because the kid who cut it didn't know the definition of square!Sent from my XT907 using Tapatalk
Reply:[QUOTE=Justin Ray Wert;4094781]Making a giant sawhorse for all our material just thought I'd share! Had to fill a bunch of gaps because the kid who cut it didn't know the definition of square!That's awesome welding a saw horse, while standing on a saw horse.
Reply:Haha the chair was to short what can I say!Sent from my XT907 using Tapatalk
Reply:I discovered this interesting thing used to elevate yourself to the level of the work, its english name is a "ladder"...
Reply:And when I realized I didn't have this "ladder" I compensated and used a saw horseSent from my XT907 using Tapatalk
Reply:Originally Posted by Justin Ray WertAnd when I realized I didn't have this "ladder" I compensated and used a saw horseSent from my XT907 using Tapatalk
Reply:I what is this mighty sawhorse meant for? I would feel more comfortable under it (loaded) if you added some kind of bracing between the legs. Seems like it wants to spread appart telling by the pictures!Mikel
Reply:Sorry if this sounds harsh but it looks to me like you guys should have put a lot more thought into your design before you started hacking up material.
Reply:Looks like it would be better suited to hang a big porch swing from.
Reply:Or may be better yet a place to hang these students Instructor from.
Reply:If you people would pay attention to the post I said I'm making not made. Its not just gonna have one beam across and I will show you the welds themselves since everybody seems to be teared up about the "design"Sent from my XT907 using Tapatalk
Reply:Justin, part of learning is learning correctly. Bad habits are hard to break and often times when you get to the point in your future where you come upon a job you really want you don't want to loose it right away because you have brought "bad" habits along with you. Standing on chairs and sawhorses isn't the way that most quality shops operate and an OSHA inspector would have a coronary if he/she saw that method of working. As to your instructor, he/she "should" cover this sort of thing and explain it in a perspective that properly prepares you for the future. No, don't simply tell someone not to do something, explain why it's important to do it in a particular manner or not do it at all.As to the attitude in your last post, the folks who have made design comments likely have a lot more years of experience with working around design challenges and properly addressing the building of these sorts of things. Don't simply get your hackles up, maybe listen and learn a thing or two. Or, instead of firing back, include the additional design description to put the concerns of others to rest. If you carry that same attitude to a job you might just find that your employment is short lived and your health and safety could be at risk as well.My comments are not to slight or put you down, hopefully these will serve as a reality check for your career down the road. Good luck and best regards, Allanaevald
Reply:Justin,Believe me, I can hardly wait to see the finished product so I can steal your idea.   snicker
Reply:Originally Posted by aevaldJustin, part of learning is learning correctly. Bad habits are hard to break and often times when you get to the point in your future where you come upon a job you really want you don't want to loose it right away because you have brought "bad" habits along with you. Standing on chairs and sawhorses isn't the way that most quality shops operate and an OSHA inspector would have a coronary if he/she saw that method of working. As to your instructor, he/she "should" cover this sort of thing and explain it in a perspective that properly prepares you for the future. No, don't simply tell someone not to do something, explain why it's important to do it in a particular manner or not do it at all.As to the attitude in your last post, the folks who have made design comments likely have a lot more years of experience with working around design challenges and properly addressing the building of these sorts of things. Don't simply get your hackles up, maybe listen and learn a thing or two. Or, instead of firing back, include the additional design description to put the concerns of others to rest. If you carry that same attitude to a job you might just find that your employment is short lived and your health and safety could be at risk as well.My comments are not to slight or put you down, hopefully these will serve as a reality check for your career down the road. Good luck and best regards, Allan
Reply:And also I didn't design it or put it together I just welded where I was told to if I designed it it wouldn't look like this that's for damn sure, the high schoolers here put it together and I had to cover all the bad welds and now they want me to add shelfs to itSent from my XT907 using Tapatalk
Reply:I mean they used a level on slanted ground they didn't square it they didn't measure right I had to fill globs of metal half inch gaps Sent from my XT907 using Tapatalk
Reply:So what you're telling us is....Mistakes were made, others will be blamed.
Reply:Originally Posted by 4956So what you're telling us is....Mistakes were made, others will be blamed.
Reply:Only 18 and graduating college? What kind of college is that?Btw, It's not a good practice naturally, but I stand on random stuff all the time .....buckets, milk crates, paint cans, wood blocks, the rung above the "do not step above this rung" - etc...Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Originally Posted by MinnesotaDaveOnly 18 and graduating college? What kind of college is that?Btw, It's not a good practice naturally, but I stand on random stuff all the time
Reply:Originally Posted by Justin Ray WertIts a technical college, long story on how I'm graduating college at 18Sent from my XT907 using Tapatalk
Reply:Originally Posted by MinnesotaDaveGood luck to you and congrats on finishing schooling how ever you got it done
Reply:It is ladder, not latter. No one here is butt hurt either. I can tell you, you would not do that working for me, and that you will not make it in the field with a 'tude like that. Good luck.
Reply:Originally Posted by walkerIt is ladder, not latter. No one here is butt hurt either. I can tell you, you would not do that working for me, and that you will not make it in the field with a 'tude like that. Good luck.
Reply:Poor little fella, he's caught between some of us more experienced hands here on the forums and what appears from all indications to be an instructor / supervisor that really doesn't have all that much fabrication experience either.   What's a young lad to do?Originally Posted by MinnesotaDaveBtw, It's not a good practice naturally, but I stand on random stuff all the time .....buckets, milk crates, paint cans, wood blocks, the rung above the "do not step above this rung" - etc...
Reply:Originally Posted by CEPI always used a ladder, and safety belt.
Reply:Are you welding with your jeans tucked in your boots?Miller trailblazer301gLincoln sa200Miller251Miller spectrum 625Victor oxy-acc2002 Chevy duramax 3500 dually 4x4
Reply:Originally Posted by MinnesotaDaveYep, too high for me! Three scaffold sections up and that's as far as I wanna go I'm not scared of heights, technically I'm scared of the ground.....
Reply:Originally Posted by BlackbeardAre you welding with your jeans tucked in your boots?
Reply:Originally Posted by MinnesotaDaveI'm not scared of heights, technically I'm scared of the ground.....
Reply:Originally Posted by pin2hotHere ya go Dave.  Will get you away from that which you are afraid.  Tim
Reply:Originally Posted by CEPOne time on a pile driving job, that crane with the black boom, the operator got the pile driving leads into the boom and knocked loose some lacing near the boom tip. I had to carry a torch up the leads and jump about 6-feet to the boom to cut the lacing out and throw them down.
Reply:I didn't think I could hold my breath for over seven minutes!!!!!!
Reply:Originally Posted by shortfuseI didn't think I could hold my breath for over seven minutes!!!!!!
Reply:so whats the point of this giant sawhorse?Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:I guess I better get hooked on phonics I don't spell to his specifications haha and its just to stack extra material on that we have over here anywhere from 14 gauge to 3/4 inch steelSent from my XT907 using Tapatalk
Reply:Originally Posted by Justin Ray WertI ain't gonna work for somebody who pushes issues Sent from my XT907 using Tapatalk
Reply:My phone auto corrects get off my thread and my back, your causing more problems then need beSent from my XT907 using Tapatalk
Reply:There's a huge difference between the way I spell and something that goes against OSHA, this is not OSHA. Bashing my spelling isn't doing anything but showing how ignorant you are, so cry me a riverSent from my XT907 using Tapatalk
Reply:Justin,There's much worse things out there to be hooked on than "phonics".   And another thing.... that guy that corrected your spelling of "ladder"....those aren't "his" spelling specifications.   Those are generally accepted "specifications" when it comes to spelling.
Reply:Originally Posted by 4956Justin,There's much worse things out there to be hooked on than "phonics".   And another thing.... that guy that corrected your spelling of "ladder"....those aren't "his" spelling specifications.   Those are generally accepted "specifications" when it comes to spelling.
Reply:Originally Posted by Justin Ray WertThere's a huge difference between the way I spell and something that goes against OSHA, this is not OSHA. Bashing my spelling isn't doing anything but showing how ignorant you are, so cry me a riverSent from my XT907 using Tapatalk
Reply:Originally Posted by Justin Ray WertI really don't care this is a internet thread not a college essay Sent from my XT907 using Tapatalk
Reply:Originally Posted by 4956That's a seriously improper conclusion to draw.  For one thing I think there's probably more similarities between the way you spell and " OSHA" than there are differences.   In many places both of those things appear to be fairly arbitrary to me.
Reply:Originally Posted by 4956Well see now, that's where you're really f*ck'n up.   You ought to be treating every post you make here as if it were preparation for writing a college essay.  ...
Reply:How about you FedEx mel a Liter bottle of Pendleton instead?   I'd have more use for that than another Gold Medal.
Reply:You really don't quit do youSent from my XT907 using Tapatalk
Reply:Originally Posted by Justin Ray WertNow your becoming vulgar torwards me? If your gonna take this to a personal level message me if not quit wasting my time with your pointless ongoing postsSent from my XT907 using Tapatalk
GMT+8, 2025-12-31 09:44 , Processed in 0.104718 second(s), 18 queries .
