查看: 13|回复: 0
sa200 help
发表于 2021-8-31 22:31:48 | 显示全部楼层 |阅读模式
Well I finialy got fire out of the old girl after I found that someone had been in the mag. and disabled the points .Now I cant get any gas to go through the carb. Thmachine sat for a few years and the carb most likley needs to be rebuilt . I dont know about an updraft carb.How are they and are they hard to deal with ? If any body has any info I would appreciate it alot .Thanks . O By the way when I sprayed starting fluid in it she did fire off a couple times .Thanks ....
Reply:Disassemble the carb, clean it, blow compressed air through ALL the holes and put it back on.  It should run.  There is no magic in a carb, especially an updraft. DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:Thanks . Do you know how to tell how old the machine is ?The outside has been painted grey .It looks like the front where the switchs are was black and white . It has a delco reme starter , the exaust manufold says red seal .The round part that sticks out the front sticks out about 11 or 12 inchs or so .Thats about all I know about it . I was the last person to weld with this mach. about 4 or 5 years ago . Thanks again and have a nice day ...
Reply:whats the code on the face plate? when you get that, go to www.firstratefabricators.com they have a code list that tells you what year it is.
Reply:Thanks alot ,someone told me since it has an octagon shaped generater that it was early 70 to early 90 .They also said it would out last me ,I can only hope so . Thanks again and have a nice day...
GMT+8, 2025-12-31 09:52 , Processed in 0.099268 second(s), 18 queries .
