Help with ranger 305G !!!!!!!!
发表于 2021-8-31 22:31:47 | 显示全部楼层 |阅读模式
Hello all this is what I;m dealing with when i start my welder while on cc-stick mode the digital output meters don't say steady the numbers jump all over the place I can run the machine but i want to say it runs funny when i weld any help would be great.
Reply:Call lincoln, they have a guy just for gas driven welders.  He knows his stuff.DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:That may be a mode switch problem, if it only happens in CC Stick mode.  Some older models will default to CC-Stick if the mode switch is unplugged from the control PC board.  That's an easy test for a grounded or tracking mode switch.  It could also be a number of other things, like long and coiled cables, poor welding cable connections (If the preset amps are steady).  Bad potentiometers if more than CC stick mode is giving problems.  More details about the problem would be helpful.Good Luck,Bob
Reply:Look for simple things first. My TB wavered a bit when I had a bad ground cable. Loose wires, bad connections, bad switches, loose fittings are easy fixes and very hard for techs to track down over the phone. When the simple stuff has been eliminated, then the bigger items will come into play. I was recently reminded of this when we were working with Miller tech trying to track down my voltage problem. The bad cable threw us for a loop until we found it.
Reply:thanks guys I'll check my connections first used it today and it didn't do it so I'll start with the basics first
GMT+8, 2025-12-31 11:42 , Processed in 0.107884 second(s), 18 queries .
