quieting a air over hyhydraulic ram?
发表于 2021-8-31 22:31:42 | 显示全部楼层 |阅读模式
im putting the hf 8 ton ram on my jd2 bender like i have seen lots of people on her do but i was woundering if there was a way to make it a little more quiet since most of my bending is done out side? thabks for your helpSIN CITY METAL WORKSvisit my YouTube channel https://www.youtube.com/user/devvon
Reply:Looks like an air operated hydraulic pump rather than air over hydraulic.   is there some way to muffle the exhaust port??? I have 0 experience but thats where I would start . . .-- fredLincoln 180C MIG
Reply:I've seen some redneck tube benders with a power steering pump and an electric motor.  Runs very  quiet.  Maybe not what you're looking for since it would require totally replacing the pump rather than fixing the one you have.Dynasty200DX w/coolmate1MM210MM VintageESAB miniarc161ltsLincoln AC225Victor O/A, Smith AW1ACutmaster 81IR 2475N7.5FPRage3Jancy USA1019" SBAEAD-200LE
Reply:Heya Devvon, haven't been able to get ahold of you...just wondering what's up with the oil holder you were making me.  I've tried calling you, sending you PM's, even posted a message in your profile.  I know this has nothing to do with your question, but I gotta find some way to get ahold of you since I've already paid and just can't seem to get ahold of you to find out what the status is.--Wintermute"No man's knowledge here can go beyond his experience." - John Lockewww.improvised-engineering.comManufacturer Agnostic:Blood----------Sweat---------Tears----|------------------|----------------|----Lincoln Red, Miller Blue, Esab Yellow
Reply:Hello wd40prerunner, I am not familiar with the particular set-up for the exhaust on that jack, does it have ports or a threaded outlet for the exhaust? As others have mentioned, a "muffler" on the exhaust will help to reduce some of the noise. If it has a threaded connection you should be able to plumb it to a cannister of some sort with fiberglass baffling or some other sort of muffling medium. If it has ports, you may be able to wrap these with some towels, batting, insulation, or other muffling medium and then tape this stuff in place. Get creative and see what you can come up with, those types of hydraulic/jack units work on a piston system and they do make a bit of noise as they are cycling. Good luck and best regards, Allanaevald
Reply:Google "muffler pneumatic" a lot of options show up.I offer three choices: Good, Fast, & Cheap. You may pick two.Hobart AC/DC StikMate LXHarbor Freight AD HoodHarbor Freight Industrial Chop SawDeVilbis 20 Gallon, 5 HP Compressor
GMT+8, 2025-12-31 09:52 , Processed in 0.100277 second(s), 18 queries .
