查看: 13|回复: 0
FS: Lincoln Idealarc 250/250 w/dynafluw cooler
发表于 2021-8-31 22:31:34 | 显示全部楼层 |阅读模式
Hi, I ended up owning another newer machine so I need to get rid of one my Tigs. Bought this around 2 years ago from a guy that did aluminum boat repair. Great condition. Cleaned the internals after I bought it, and bought a new torch with hoses a little while ago. Last pic shows a bent mounting rail...(chain broke on a hoist while i was loading my truck....truck ended up looking much worse...) Just cosmetic....machine works flawlessly.specs:- Lincoln Idealarc 250/250           - Ck watercooled torch 25tf hoses          - Dynaflux R1000 cooler          - 30ft. Ground lead          - All coolant and gas hoses includedLooking to get: $850  local pickup onnly located in Staten Island NYpics:
Reply:Update: Just realized I have a spare 60 cu argon tank and a Harris Regulator that go with this welder. pics:
Reply:bump !!!!!!!!!
Reply:bump
Reply:bump
Reply:PM sent
GMT+8, 2025-12-31 13:22 , Processed in 0.112814 second(s), 18 queries .
