350p guys question for you t joint
发表于 2021-8-31 22:31:31 | 显示全部楼层 |阅读模式
So I'm playing with the 350p in pulse mig mode and just practicing t joints.  I noticed arc tends to wander from one side of metal to other Any advice on what I am doing wrong or setup ?I can certainly mig it no issues but I see globs one side and if the arc wanders to the other side globs on other sideDo I need to sharpen my arc so it's more focused in the corner ?Thanks in advance
Reply:Originally Posted by padronanniversarySo I'm playing with the 350p in pulse mig mode and just practicing t joints.  I noticed arc tends to wander from one side of metal to other Any advice on what I am doing wrong or setup ?I can certainly mig it no issues but I see globs one side and if the arc wanders to the other side globs on other sideDo I need to sharpen my arc so it's more focused in the corner ?Thanks in advance
Reply:Your having arc blow probs. Lower settings and back step. I get that prooblems sometimes welding in corner or t joint. its frustrating to say the least.HH140---------------------------https://www.facebook.com/brandon.pike.9
Reply:Things are very good now, although I am still getting spatter in pulse for some reason
Reply:you guys rock.  When you say back step, what exactly do you mean by that ?  Thanks again all !
Reply:Here bud read this artical. It will explain arc blow and how to fix it. Understand some info wont pertain to u depending on what process u arre doing: lincolnelectric.com/en-us/support/welding-how-to/Pages/preventing-arc-blow-detail.aspxMiller & Lincoln website has alot of great information on there sites. I recommend reading some of it when your bored. I will say Lincolns site has the most info.HH140---------------------------https://www.facebook.com/brandon.pike.9
GMT+8, 2025-12-31 09:44 , Processed in 0.103952 second(s), 18 queries .
