E7018 restarts
发表于 2021-8-31 22:31:31 | 显示全部楼层 |阅读模式
I was just curious on some good ways to do nice restarts with E7018. Especially with weaves.
Reply:Hello bruceshultis, a quick description of one method goes something like this: strike your arc slightly above the crater that has been left by where you ended your bead(I usually try to end a weave at one side or the other) and then pause just long enough to fill this crater and then resume the progression that you have been using for any additional bead deposition. Don't long arc, keep the arc tight. Good luck and best regards, Allanaevald
GMT+8, 2025-12-31 09:52 , Processed in 0.107025 second(s), 18 queries .
