Stick Welders AC Vs. DC ???
发表于 2021-8-31 22:31:30 | 显示全部楼层 |阅读模式
What are the pros and cons of AC vs. DC in stick welding ???
Reply:Pretty common subject, here is one thread on it:http://weldingweb.com/vbb/showthread.php...hlight=Hate+ACWhy do you ask by the way?Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Originally Posted by MinnesotaDavePretty common subject, here is one thread on it:http://weldingweb.com/vbb/showthread.php...hlight=Hate+ACWhy do you ask by the way?
Reply:Good stick welders, if I needed one I wouldn't be worried.But I thought you liked tig? Your tig machines don't stick weld?Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Yeah.......they do........just a thought.........you know.........always wanting to puntz with another machine!!!I don't like TIG the best........trying to get better at all processes of welding !!!
Reply:I hear you - the thunderbolt will lay down some good 7014, 6013, 7018AC rods for you Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:If you need a simple arc welder not much will beat one of those buzz boxes for $150.You be suprized how much you can do with AC only, all the lincoln rods a lowes and walmart that I have tried run AC real well.old Miller spectrum 625 Lincoln SP-135 T, CO2+0.025 wireMiller model 250 and WP-18V torchCraftsman 100amp AC/DC and WP-17V torchCentury 115-004 HF arc stabilizerHome made 4 transformer spot welderHome made alternator welder
Reply:AC gets a bad rap.  As said earlier very good work can be done with the correct rods. I use it for the equipment I repair because the arc blow makes it difficult to weld on dc.Idealarc 250AC 225SVictor OA-older made in USA stuff.And a crap ton of other stuff.
Reply:Originally Posted by rahtreelimbsYeah.......they do........just a thought.........you know.........always wanting to puntz with another machine!!!I don't like TIG the best........trying to get better at all processes of welding !!!
Reply:I think every welder should learn on an AC welder so transitioning over to DC will be easy. Learning on DC is easy but transitioning over to AC isn't so easy.Nothing wrong with an AC welder, I've seen some outstanding welds with AC welders. Also, AC has some properties that work well welding magnetized metals and arc blow.
Reply:Thanx Guys!!!
GMT+8, 2025-12-31 09:44 , Processed in 0.121246 second(s), 18 queries .
