Lincoln Wire Feed Tap or Continuous
发表于 2021-8-31 22:31:29 | 显示全部楼层 |阅读模式
What is the difference between the tap version and the continuous?I know that the tap is a preselected voltage source and the continuous the voltage can be re-fined. But what would be the advantage or disadvantage.Thanks,
Reply:the advantage would be to set the machine to how you want to weld, rather than change the way you weld to suit the machine.
Reply:So it would be better to get the Continuous Version.
Reply:The continuous machines are generally only sold by the Welding companies rather than the local big box stores. If you have a choice, get the continuously variable version. They are more versatile.Miller Millermatic 252Miller Syncrowave 200Liincoln AC-DC 225Victor O-A Set
GMT+8, 2025-12-31 09:44 , Processed in 0.101636 second(s), 18 queries .
