查看: 13|回复: 0
lincoln tombstone tig ?
发表于 2021-8-31 22:31:28 | 显示全部楼层 |阅读模式
I see this on ebay,my ? is has any body tried this? where can i get the hf box? I have the same welder and would like to do hobby work using some of what i already have  Attached ImagesVictor SuperRanger O/A                                         Solar migLincoln Powermig 140Southbend 9in lathe350# kohlswa anvilMiller Maxstar 150 stl etc....
Reply:Go see your nearest Lincoln dealer they will hook you up.Lincoln Power Mig 200Ready Welder spool gunLincoln Tomb Stone AC DCMPM 150 AMP DC portable Arc welder and GeneratorRiland 40 AMP Plazma Cutter
Reply:Google search for Lincoln Electric K-799 Hi-freq kit.WeldingWeb forum--now more sophomoric banter than anything else!
Reply:No luck apparently they don't sell the kit anymore,anybody got any ideas how to make my welder tig? Victor SuperRanger O/A                                         Solar migLincoln Powermig 140Southbend 9in lathe350# kohlswa anvilMiller Maxstar 150 stl etc....
Reply:Go to a "chain store", Airgas, S.J.Smith, etc. Have them look in their database, lot of times the it's only way to find stuff stuck away on dealers shelves. The national chains have complete company inventory lists normally.Anything worth doing is worth doing RIGHT
Reply:You can buy the old Lincoln hi-freq box for 125.00. The later one in the picture would probably be more like 300 to 400 used. Here is why you may not want to go this route (I am guessing your real goal is aluminum).     Your Lincoln AC side is too small for realistic work since you should lower rating for ac tig because of the rectification effect of oxide layer on aluminum causing dc current to flow in transformer and you don't have a lot of capacity to start with.     Your torch is always 'hot' - very aggravating.      You cannot adjust your welding current remotely - aggravating again.     After it is all said and done, you can buy a real tig many places from 'dirt cheap' right up thru lower than reasonable. The real money only occurs in the newer Miller, Lincoln, Esab, etc. Lastly, don't be intimidated by size - if you can run that little Lincoln, you can run a big boy machine, and they weld like a dream. Make clark-kentski one happy welder fellow. Worked for me for years. weldersales
GMT+8, 2025-12-31 12:45 , Processed in 0.139919 second(s), 18 queries .
