sa 200 help?
发表于 2021-8-31 22:31:28 | 显示全部楼层 |阅读模式
Hello again guys after further inspection and removeing the mag. I found it has some broken parts as well as the governor . Do any of yall know where I can find a good used mag. and governor .Looking at weldmart online they are realy pricey . And after they sent me the wrong carb. kit and not taking it back I am not sure I would trust those people again .Thanks guys and have a nice day .....Thomas....
Reply:you can get the rebuild kit for the govener from (tractor supply .com) and if the carb is a zenith or marvel shrieber you can get the whole carb or rebuild kit from (zenith fuel systems .com). and the mag is no prob, I will get the name of the place that deals with fairbanks and american bousch mags , but I will tell you this if you can get the parts and rebuild it your self by all means do, replacement mags can realy make your wallet thin ,
Reply:Thanks for the info I can rebuild anything if I have the parts .The carb is good now but I do still need parts for the mag. and the governor .Thanks again and have a nice day ....Thomas.......
Reply:(american eletric ignition ) has all the mag parts and manuals as I recall american boush mags are timed off #1 cylinder and fair banks are timed off #4 cylinder . and your mag is a fairbanks from what you said having FM on some of the parts take extra time to find out the rotation , if the mag was replaced with wrong mag that could be why you have broken parts.
Reply:Hey boilermaker that site for the mag. parts seems to be what I need .I cannot find the parts for the governor at tractor supply .com .I dont know what tractors came with f163 motors on them .I would take used parts if I could get them or rebuild parts . Hey man thanks alot you have been a big help ......Thomas....
Reply:ok try (continental industrial engine parts) they usualy have a good stock pile of used parts
GMT+8, 2025-12-31 09:44 , Processed in 0.103566 second(s), 18 queries .
