Lincon tig 300/300
发表于 2021-8-31 22:31:27 | 显示全部楼层 |阅读模式
hi can someone tel me where i can order a pc control bord for my tig 300 welder it's fried. by mistake :-( something stupid i did by mistake i relay need a new board the stick part of the welder works fine but i can strike an arc with the tig side.thanksJason
Reply:Originally Posted by RoosterBoyhi can someone tel me where i can order a pc control bord for my tig 300 welder it's fried. by mistake :-( something stupid i did by mistake i relay need a new board the stick part of the welder works fine but i can strike an arc with the tig side.thanksJason
Reply:Do you have the older model that is about two feet wide and four feet tall? Is the model number Tig 300/300? Red or black nameplate?     weldersales
Reply:Originally Posted by weldersalesDo you have the older model that is about two feet wide and four feet tall? Is the model number Tig 300/300? Red or black nameplate?     weldersales
Reply:if you havent try the lincoln web sight , they do have a stock pile of parts and you might be surprised, or call aweco in phoenix az they have a large inventory of older machines and a repair man that has a large stock of older machines
Reply:wow im sorry guys i completely forgot about this post the machine i have is a idealarc tig 300 300 and the code number is 8888-c im looking for a pc timer control board.also can someone tel me how to test the high frequency transformer?the unit runs Grete in stick modethank you
Reply:Originally Posted by RoosterBoywow im sorry guys i completely forgot about this post the machine i have is a idealarc tig 300 300 and the code number is 8888-c im looking for a pc timer control board.also can someone tel me how to test the high frequency transformer?the unit runs Grete in stick modethank you
Reply:As far as testing your HF transformer, it would be impossible if your TIG side isn't working. When the TIG is working and HF is on continuous, you can hear it and also the arc will start by just approaching the work piece. I think you need more help that we could give you here, though. Good luck Miller Millermatic 252Miller Syncrowave 200Liincoln AC-DC 225Victor O-A Set
Reply:Don't mean to hijack your thread here, but I have a chance to buy one of the Lincoln TIG 300. It's an older machine but in great shape. Seller wants $500.00 for it. The welder has been stored for a period of time and I can't test it. So thats why Im asking....
Reply:Originally Posted by GearheadDon't mean to hijack your thread here, but I have a chance to buy one of the Lincoln TIG 300. It's an older machine but in great shape. Seller wants $500.00 for it. The welder has been stored for a period of time and I can't test it. So thats why Im asking....
Reply:Olddad,The machine is single phase and how do I check for the power correction board.. Thanks for the help here....
Reply:Originally Posted by GearheadOlddad,The machine is single phase and how do I check for the power correction board.. Thanks for the help here....
Reply:Also try a company called "Innovat Corp". They will rebuild the board for 1/2 what a new one will cost you. 1-800-626-1887. Located in Marion, VA
Reply:I have a 1996 Idealarc Tig 300/300 that is red with a black panel.  I bought it used from the local used to be Holox, then became Linde, now is Airgas dealer who had it in thier rental fleet.  The funny part is the company I worked for was the only one that ever rented it, so I knew how little it was used.  Anyway, immediately after I got it home the high frequency went out on it.  Knowing just enough about electronics to be dangerous I did some tests and decided the high frequency capacitor was out.  I asked the guy that sold it to me to get me a new capacitor, but he insisted on houling it back in to thier repair facility.  This thing weighs about 890lbs without a bottle, so that was a pain...  Got it back three weeks later with a ticket saying they replaced the hi-freq capacitor, no charge but at least it had broken loose on one of the truck rides and banged up the case and bent the handle good.  Sure would have been easier to give me the little capacitor!Anyway, I love this machine.  I know it sounds crazy, but I'd pick it over the Synchrowaves I have access to any day.  Seems like a much more stable arc, specially in AC, and has much better low amp characteristics.Jason
Reply:Originally Posted by TubularFabAnyway, I love this machine.  I know it sounds crazy, but I'd pick it over the Synchrowaves I have access to any day.  Seems like a much more stable arc, specially in AC, and has much better low amp characteristics.Jason
GMT+8, 2025-12-31 13:16 , Processed in 0.264014 second(s), 18 queries .
