What is a step up for the HF ring roller
发表于 2021-8-31 22:31:26 | 显示全部楼层 |阅读模式
I purchased a HF gear driven planetary ring roller a month ago.  It is already showing major wear, partly my fault, partly the fact that it is HF cheep.  No matter I have already gotten my moneys worth out of it, however I am soon going to need to replace it.  I am guessing with the learning curve out of the way this one should last longer but I want one a bit nicer than the HF model.  THe one from HF is $69, the next cheapest one I found on line was almost $600 , First off is the $600 one worth the price?  Are there other options?  I have been using this for various round stock up to 1/4" and for 1/8" flat stock, but if the machine would do bigger I'd go bigger.
Reply:Originally Posted by natz803I purchased a HF gear driven planetary ring roller a month ago.  It is already showing major wear, partly my fault, partly the fact that it is HF cheep.  No matter I have already gotten my moneys worth out of it, however I am soon going to need to replace it.  I am guessing with the learning curve out of the way this one should last longer but I want one a bit nicer than the HF model.  THe one from HF is $69, the next cheapest one I found on line was almost $600 , First off is the $600 one worth the price?  Are there other options?  I have been using this for various round stock up to 1/4" and for 1/8" flat stock, but if the machine would do bigger I'd go bigger.
Reply:shop outfitters s-ck
GMT+8, 2025-12-31 11:44 , Processed in 0.084784 second(s), 18 queries .
