getting thermal dynamics cutmaster 82
发表于 2021-8-31 22:31:26 | 显示全部楼层 |阅读模式
im buying the cutmaster 82  anybody have this model that can give me some input on these machines  thanks
Reply:I am very happy with my cutmaster 52. The cutmaster 82 is the same machine with 20 more amps of cutting power than the 52 has. You wont be sorry you made the purchase.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:I have the cutmaster 81 and I've been very happy with it.  I'm not sure what all changed between the 81 and 82, but I think mine is just the older generation.Dynasty200DX w/coolmate1MM210MM VintageESAB miniarc161ltsLincoln AC225Victor O/A, Smith AW1ACutmaster 81IR 2475N7.5FPRage3Jancy USA1019" SBAEAD-200LE
Reply:The cutmaster 81 was a 60 amp machine. The cutmaster 82 is a 80 amp machine.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:I also have the Cutmaster 52, I like it a lot. I really like the drag feature for hand held cuts. Very easy to set up and operate. Be sure to get the best air filter/ drier that you can; i.e. Motorguard brand
GMT+8, 2025-12-31 13:19 , Processed in 0.097713 second(s), 18 queries .
