Dewalt Chop Saw Choice
发表于 2021-8-31 22:31:25 | 显示全部楼层 |阅读模式
$155 for the regular non quick detach or$180 for the quick detach?Is the a better chop saw new for $150?  Is the quick detach worth it for $30.  Very light hobby use so don't plan to change blades often.
Reply:Same exact price from Amazon.  Besides the base are the motor, blade, longevity comparable?
Reply:Just my .02 I have a hitachi abrasive chop saw and recentley bought an evolution sliding compound miter saw with a steel blade. It was the cheaper one, about 160$ I think, and wow. I dont think i'll ever use the chop saw again. It cuts 8 in. 14 ga. c-purlins like its wood. I cut some 1/4 in. plate with it the other day and it just ate right through it. Its 10x better than an abrasive saw imo.
Reply:The chopsaw from Homedepot is the Rigid 14" mod# cm1450.   I like this one because of Tacks advice about the base. The Rigid has a  CAST IRON base.  Its strong, wont flex.....and is heavy enough to withstand abusive weights from large pcs. of metal.A quick change device....WHY?  It take just a moment to change a blade normally....so what are you saving?  10 seconds?Price on the Rigid is 179. online.    I got mine for a lot less by taking a flyer into a store with a coupon...I got 20% off one item.....I got the saw.Now...with that said, If I were you and starting out fresh.....Id look into a low RPM cold cut saw with a metal blade.  Evo makes one, so does everyone else.  there are some great threads on this  site about them....  read up, be an INFORMED CONSUMER.Lincoln IdealArc 250 AC/DC  w/ tigLincoln Ranger 8Miller Millermatic 140Victor Cutting setForney gas welding setMilwaukee power-tools3 legged dog named SpeedyFridge full of Diet Coke1 angry wife2 loud kids
GMT+8, 2025-12-31 11:44 , Processed in 0.086554 second(s), 18 queries .
