Has anyone heard of AMP (Air Movement Products) Compressors?
发表于 2021-8-31 22:31:24 | 显示全部楼层 |阅读模式
Like the title says; has anyone heard of AMP (Air Movement Products) air compressors? They are or were out of Rochester NY.I picked up an 80 gallon two stage verticle unit. It looks identical to a Saylor Beall and am beginning to wonder if it wasn't a private label SB based upon the pump and tank configuration. It is rated at 23CFM displacement. I timed the pump as it built pressure and from 0 to 175 psi it produced roughly 15.5 CFM.Model # X51-C22A-80v Thanks for any help.
Reply:Here's a picture
GMT+8, 2025-12-31 13:21 , Processed in 0.071940 second(s), 18 queries .
