made a couple yard art things
发表于 2021-8-31 22:31:21 | 显示全部楼层 |阅读模式
made these from pieces left over from previous projects.Lincoln 225 ac (my first machine)farmhand 115vac 70amp mig/fc toymiller aead 200le (my main machine)
Reply:I like the windmill!Its always been on my list of things to build!
Reply:It looks like the windmill doesn't swivel or rotate, am I right? If so, why didn't you make it so the blades would turn and it would face the wind? It would be fairly easy to do and make it more interesting to see it in action.
Reply:+1 for the windmill and having it turn.Sent from my iPhone using TapatalkLincoln Pro Mig 180HF Stick/Tig Inverter WelderLincoln AC225s
Reply:Dig the windmill.  Looks good!Lincoln Power Mig 216Lincoln AC/DC-225/125Miller  625 X-Treme PlasmaMiller 211 Forney 95FI-A 301HF 91110Victor Journeyman O/PMilwaukee DaytonMakita  Baileigh NRA Life Member
Reply:With our wind that windmill could run my welder!Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:Originally Posted by Robert HallWith our wind that windmill could run my welder!
Reply:I'll send a few pigeons through it as a test.Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:Originally Posted by Robert HallI'll send a few pigeons through it as a test.
Reply:Originally Posted by BistineauIt looks like the windmill doesn't swivel or rotate, am I right? If so, why didn't you make it so the blades would turn and it would face the wind? It would be fairly easy to do and make it more interesting to see it in action.
Reply:Going to need some more surface area on the blades........ Much more, those squabs will fly right thru those that are there now.Magazines have issues, everything else has problems
Reply:the next yard art project is this semi truck and trailer. some of you remember the air compressor tank with the file welded to the bottom in the welding fail thread, well I found a good use for it. here is the start of the tractor.and this will be the trailer.Lincoln 225 ac (my first machine)farmhand 115vac 70amp mig/fc toymiller aead 200le (my main machine)
GMT+8, 2025-12-31 11:40 , Processed in 0.138152 second(s), 18 queries .
