Got a kijiji deal on two helmet, need some thoughts
发表于 2021-8-31 22:31:20 | 显示全部楼层 |阅读模式
Ok guys, been a bit since i welding, i moved and misplaced my helmet, its in a box somewhere in one of 50 boxes, in 3 different locations LOLbut it was just a knock of helmet, so i have been in search of a new to me helmet for a few months, Got a deal on 2 "broken" welding helmets for 40 bucks. 1 is a miller performance helmet and the other is a esab aristo tech.... the performance was a dead battery/dirty sensor and the esab the solar cell had a broken wire/dirty sensor, so they are both fixed but i cant seem to decide which one i like, plus im still tweaking the settings and not sure what i should run roughlySo my question is who has either of those, do you like it and what settings are you running? i figure instead of flashing myself a lot, ill get a base line from you guys on what settings you runCentury 88amp 110v migCentury 100, 110migPowcon200smThermal Arc 140 migThermal Arc Fabricator 211i
Reply:You don't get arc flash even if the helmet doesn't darken.   Even non activated you are still protected from the UV rays.Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
GMT+8, 2025-12-31 11:43 , Processed in 0.156001 second(s), 18 queries .
