SS Question
发表于 2021-8-31 22:31:19 | 显示全部楼层 |阅读模式
Hi all, I'm making a replacement BBQ grill using 304 stainless.  I know I should use a 308 electrode but I already have some 309/309L lincoln electrodes.  Also a small box of 308 has been hard to find.Do you think I'm ok just using the 309 filler?Thanks again,Matt
Reply:I'd use the 309. It's a grill.This page has more details. http://www.lincolnelectric.com/en-us...al-detail.aspx Some 308L applications may be substituted with 309L filler metal, but 316L or 316 applications generally require molybdenum and 309L contains no molybdenum.
Reply:Originally Posted by forhireI'd use the 309. It's a grill.This page has more details. http://www.lincolnelectric.com/en-us...al-detail.aspx
Reply:My impression is that it is usually ok to use the higher number filler on lower numbered plate.  The corrosion resistance is higher with the higher numbered filler in stainless.  I tried to get some 317 filler for my 316 SS water heater the other day, but just gave up and used the more common 316L filler.Miller Syncrowave 350Millermatic 252/ 30A spoolgunMiller Bobcat 225g w/ 3545 spoolgunLincoln PowerArc4000Lincoln 175 Mig  Lincoln 135 Mig Everlast 250EX TigCentury ac/dc 230 amp stickVictor O/AHypertherm 1000 plasma
Reply:Originally Posted by mattsseThank you, I guess I`m being paranoid about two things 1)  Using something that will corrode faster then the grill itself and end up with problem welds and 2)  Using something that is maybe not safe to eat off of.Matt
Reply:Well I know most good quality stainless pans are made of 304 (18/8).  My thoughts are that 304 stainless is made for high temperature applications and would never get hot enough to release anything toxic just from the heat on a natural gas or propane grill.    The 309 rods are mostly used to join stainless to mild steel but I'm not sure what else they contain.  Lincoln recommends the 308/308L rods for 304 - that's not to say 309 wouldn't work, it's just not best practice.  I'm probably being over paranoid and maybe you're yanking my chain a bit but I was just wondering what others thoughts were.Matt
Reply:I use 309,308,316,& 321 stick and tig fill wires in food processing plants. All are food safe, and won't corrode.To reiterate, is a grill. You'll be fine. Sent from my LG-D851 using Tapatalk
Reply:Originally Posted by dcoffmanjrI use 309,308,316,& 321 stick and tig fill wires in food processing plants. All are food safe, and won't corrode.To reiterate, is a grill. You'll be fine. Sent from my LG-D851 using Tapatalk
Reply:It's only a grill, you'll be fine.  Any stainless rod will work.Interprovincial RedSeal Welder and SteamfitterMiller Maxstar STL 110vMiller Blue Star DX 185Lincoln 180
Reply:It's all gonna rust after it gets hot, anyway.
Reply:A TIG machine and good clamps = no filler needed at all....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Just don't grill any meat on it.  That stuff is bad for you. "USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:Originally Posted by KelvinIt's all gonna rust after it gets hot, anyway.
GMT+8, 2025-12-31 11:41 , Processed in 0.074699 second(s), 18 queries .
