welding rod for sale & cut off wheels
发表于 2021-8-31 22:31:15 | 显示全部楼层 |阅读模式
I have some welding rod that was in my father in-laws repair shopEutectic  Xuper 680cgs ;  1/16"        ApplicationsMechanical properties are maximized for use on all difficult-to-weld steels with a special flux formulation designed to optimize weld deposit appearance...a feature demand typically required when welding tools & dies.  Ideal for applications such as jigs, molds, dies, leaf springs, high strength repairs to earthmoving, mining, constructional equipment, chassis and under carriage repairs and manganese steel omponents.     Technical dataTypical tensile strength: 120,000 psiTypical yield strength: 79,000 psiTypical elongation (l=5d) min.: 25%Typical hardness (as deposited): 90 HRBFeatures and benefits• Ideal for problem steels which need high integrity, safety and welder-friendly usability       5.5lb tube  $75.00ea  I have 12 tubes---------------------------------------------------------------------------------------------------------------------------------; Xuper 2240   1/8"ApplicationsLow-heat-input manual electrode for the "in-situ" repair and maintenance of cast iron and for joining cast iron with steels or copper alloys. Applications include pump bodies, compressors, machine frames, casting defects, lathes, pulleys, dies, levers, gears, generators, flanges, tables and engine blocks.Technical dataTypical Tensile strength: 55,000 psiTypical Hardness (as deposited): 75 HRBFeatures and benefits• Exceptional weldability in all positions• Nodular graphite deposit resists cracking• Low-heat-input • No electrode overheating• Also suitable for contaminated surfaces$75.00  1 tube  10 llb-----------------------------------------------------------------------------------------------------------------------------Cut Off Wheels 5" x 1/16 x7/8 Spedecut brand  box of 25     $25.00ea   6 boxesyou can reach me at 631-455-6361   located on long island ,ny
Reply:Tonyboy,At least the first posting was "good for a laugh".1/16" rod and mining, earthmoving, and construction equipment do not relate.At $75/tube, I hope that stuff has a long shelf life.Syncro 250 DX Dynasty 200 DXMM 251 w/30A SG XMT 304 w/714 Feeder & Optima PulserHH187Dialarc 250 AC/DCHypertherm PM 1250Smith, Harris, Victor O/ASmith and Thermco Gas MixersAccess to a full fab shop with CNC Plasma, Water Jet, etc.
GMT+8, 2025-12-31 13:18 , Processed in 0.106049 second(s), 18 queries .
