Would anyone recommend a Miller Coolmate 1 ?
发表于 2021-8-31 22:31:14 | 显示全部楼层 |阅读模式
If a guy could buy a used one for $350 to put it on a 200amp DC tig welder, should he do it???~John
Reply:NoLoud piston pump POS
Reply:So their a poorly designed/built machine???~John
Reply:Originally Posted by AKweldshopIf a guy could buy a used one for $350 to put it on a 200amp DC tig welder, should he do it???~John
Reply:I guess I'll keep looking for a Coolmate 3.Or should a guy buy a HTP cooler???~John
Reply:Had a Coolmate 3,(Binzel) and have a Coolmate one now. No issues, and really not as loud as the 3 (imo) I looked at the China made HTP, (Online) and just could not pull the trigger on it. I could see if something is off under the cover of the Coolmate one, then it could be loud, but not the case with mine. I am happy with mine, and blends in sound wise with my Thermal 186. Not the quietest tig, but not the loudest either. Size is excellent for me, and fits better then a Coolmate one, Bernard 2500 I had before..Esab/Lorch ET-220iEsab 160i caddyThermal LM-200 Lincoln feedersThermal Pee-Wee 85sThermal 60i- 3phase /RPC powered (Beast)Thermal Drag-gun 35CINE 1500 Klutch 140i
Reply:I've had a coolmate 1 at home and 2 at work , and they are real quiet, and do what they are supposed to. so I really don't know what was up withDrf255's. You will be happy with it. Bernard makes  a great cooler too. If you can find others in your area great, I've seen coolers aren't as easy to come by in my area.'14 HTP invertig 221Thermal Arc 201ts'15 HTP 2400'13 Hypertherm Powermax 30Esab 875Esab 251Clark Metal Servicespecializing in stainless steel exhaust systems
Reply:Maybe there's a variation or change in the Coolmate 1.  I've had both.  The Coolmate 1 was terribly annoying to me whereas my current Coolmate 3 is not at all.  Found myself always looking to shut the 1 off after/between welds.  With the 3, it doesn't bother me.  Could be a personal thing.
GMT+8, 2025-12-31 13:22 , Processed in 0.148446 second(s), 18 queries .
