Latest welds
发表于 2021-8-31 22:31:12 | 显示全部楼层 |阅读模式
Here are some of my latest welds. I think my skill have substantially improved. Feedback would be appreciatedSent from my SPH-M950 using TapatalkMiller Dialarc 250 AC/DCWeldcraft A-150VSmith O/P
Reply:Material is 1/8", .30" lincoln nr211, max voltage on Craftsman wirefeed Sent from my SPH-M950 using TapatalkMiller Dialarc 250 AC/DCWeldcraft A-150VSmith O/P
Reply:Looks a little cold on the toe lines. Did you use a straight stringer bead or oscillation?Sent from my C811 4G using Tapatalk
Reply:Originally Posted by swampwelder13Looks a little cold on the toe lines. Did you use a straight stringer bead or oscillation?Sent from my C811 4G using Tapatalk
Reply:I would crank up the heat a lil. Use a drag angle use a side to side motion spending no time across the middle Sent from my C811 4G using Tapatalk
Reply:I think the second one looks much better.
GMT+8, 2025-12-31 11:43 , Processed in 0.252578 second(s), 18 queries .
