Another 25 batch
发表于 2021-8-31 22:31:12 | 显示全部楼层 |阅读模式
Moving right along......  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:Very nice work! You could probably weld for money someday.Two turn tables and a microphone.
Reply:Wow you think?  that would be awesome...  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:Your headache might come from lack of ventilation, instead of bright lights. If the slightly/partially open garage door is your fresh air source, I'd be a bit hesitant to continue in that environment.  Am certainly not a welding expert but have dealt with fume issues in the past.Jerry30+ yrs Army Infantry & Field Artillery, 25 yrs agoMiller 350LX Tig Runner TA 210, spool gunLincoln 250/250 IdealArcESAB PCM 500i PlasmaKazoo 30"  vert BSKazoo 9x16 horiz BSClausing 12x24 lathe20T Air Press
Reply:Yep your correct, thats Toxic Fume poisoning for sure and the reason I just ordered a Fume recovery system...  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:BC, those tubes remind me of an ex-customer of mine. Big guy, maybe 350 pounds, with huge hands and fingers as big as hot dogs. He welded for a Boeing subcontractor and built parts that were part of their fuel systems. It was about a 3" aluminum tube with a slight bend in it. He had to weld a flange on one end and a cap on the other. He'd sit there all day long using those huge, meaty paws with one foot on the welder control pedal, the other foot on the pedal controlling the positioner speed, tig torch in one hand, filler rod in the other. Had to see it to believe it.
Reply:Looks great!
GMT+8, 2025-12-31 13:24 , Processed in 0.222520 second(s), 18 queries .
