sa 200 mig?
发表于 2021-8-31 22:31:11 | 显示全部楼层 |阅读模式
can you hook a wire feeder up to a sa 200 and mig weld? To me it would seem a bottle of gas and a cv wirefeeder would work am I wrong.
Reply:It will work if the feeder has a VV switch.  It will work far better if you get the box that makes the SA into a CV power supply.  They aint cheap.The bigger the stuff you weld, the better it will work.DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:You have to have a voltage sensing wire feeder in order to do that.  Mine is  Miller S32P, but a Lincoln LN25 or Miller 8VS or 12VS will also work.  The Sa 200 has no CV capabilities.
Reply:They do make a box but its Expen$ive.http://www.mylincolnelectric.com/Cat...eet.asp?p=2098DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:Originally Posted by David RThey do make a box but its Expen$ive.http://www.mylincolnelectric.com/Cat...eet.asp?p=2098
Reply:A SA-200 and a LN-25 with a 10' 400 amp mig gun will weld aluminum quite well. Only probs will be bending the gun cable will slow the wire down. And the starts are not perfect, otherwise the arc is about perfect, better than my trailblazer in cv mode. The trick to adjusting the welder is turning the fine current down  to around 25 and the coarse range to 4th or 5th gear (I cant remember which)
Reply:Originally Posted by WelderBoyHoly mother of pearl....Does that work on any CC power source?...
GMT+8, 2025-12-31 11:42 , Processed in 0.219133 second(s), 18 queries .
