welding blankets
发表于 2021-8-31 22:31:02 | 显示全部楼层 |阅读模式
hoping someone can educate me on which one to purchase,i need one for general cutting and mig welding in my garageim thinking for at least a 8x8 blanket but not sure what material to use or what brands are good or badthanks for helping out a newbie
Reply:Interested in the answer to this as well.
Reply:Pretty sure this link (http://adlinsulflex.com/fire-blanket...blanket-32-oz/) is to what we use in the field.  Works good for protecting when supported vertically.  Often used over plywood over grating to protect workers on lower floor.  This combination gives a reasonable amount of time to put out any molten sparks which can melt/burn their way through.  Have to realize that fire blanket on a floor is considered disposable and would be very expensive for a home set-up.  I'm not condoning any oxy-fuel burning in a wooden garage.   If you absolutely have to, then maybe consider a cutting table with a built-in water trough.
Reply:I just went to my LWS and said, "I need a welding blanket."  They had them in stock for a reasonable price.KevKevin / Machine_Punk from The Aerodrome Studio - Lincoln PowerMIG 210 MP - Meco N Midget w/custom welding station - Vintage Victor 100Current Projects: The Aerodrome Studio
Reply:I've mostly used what looks like a fiberglass cloth, comes in a roll.  You should wet it with water before use, makes it more effective and lasts longer."The reason we are here is that we are not all there"SA 200Idealarc TM 300 300MM 200MM 25130a SpoolgunPrecision Tig 375Invertec V350 ProSC-32 CS 12 Wire FeederOxweld/Purox O/AArcAirHypertherm Powermax 85LN25
Reply:Originally Posted by noriteI've mostly used what looks like a fiberglass cloth, comes in a roll.  You should wet it with water before use, makes it more effective and lasts longer.
Reply:I have the HF one.  Good quality for the price.  Esp with 20 percent of couponTiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:i wish there was as good of an answer, as the question is.      thats pretty much the only thing i go to harbor freight for.    they used to be more canvassy like, now there fiberglassy like.     i bunch them up in layers, most used blankets on top, newer ones under.     i got a bunch of old leather jackets from a school throwing them out, also
Reply:Get the coated fiberglass from the LWS. They are usually 6x6, IIRC, and run about $50. Stay away from the loose weave ones from HF, they will leave you itchy, and don't hold up well, shocking I know, being from HF and all.
Reply:once asbestos blankets were verboten i never bothered to find a replacement.i.u.o.e. # 15queens, ny and sunny fla
Reply:4 ' x 4 ' Masonite is  a nice size to handle and lay on floor for cutting. I throw a welding blanket or blankets on top. Mine are the Tilman, 6 ' x 6 ' size. I made a frame so I can use one as a wind brake or a screen. They work well. http://www.amazon.com/Tillman-Vermic...elding+Blanket
Reply:Originally Posted by BD14 ' x 4 ' Masonite is  a nice size to handle and lay on floor for cutting. I throw a welding blanket or blankets on top. Mine are the Tilman, 6 ' x 6 ' size. I made a frame so I can use one as a wind brake or a screen. They work well. http://www.amazon.com/Tillman-Vermic...elding+Blanket
Reply:I have used wet corrugated paper (cardboard box), cheap but messy.I offer three choices: Good, Fast, & Cheap. You may pick two.Hobart AC/DC StikMate LXHarbor Freight AD HoodHarbor Freight Industrial Chop SawDeVilbis 20 Gallon, 5 HP Compressor
GMT+8, 2025-12-31 13:03 , Processed in 0.144660 second(s), 18 queries .
