A question about tin plating or zinc plating mild steel
发表于 2021-8-31 22:31:00 | 显示全部楼层 |阅读模式
I've been wondering about this for a while. Let's say I have a galvanized boat trailer and since it is launching into salt water I wanted to protect an area I removed the galvanizing where I welded on the trailer.   So I ground the area of repair and welded onto the trailer with mild steel rod. My question is this....Is there a way I can now clean the weld area and heat that spot with a torch to melt some zinc onto that spot to plate it with a true galvanized coating?  I know I can spray the stuff in a can on it. I was just wondering if I can plate regular steel with raw zinc stock with a torch.FWIW...I know Zinc fumes are bad...So if its possible, could I just solder over the joints with a lead 50/50 solder. Has anyone ever done anything like this ?Last edited by Tim9; 08-14-2015 at 01:25 PM.Reason: added question
Reply:http://www.galvaguard.com/hot-stick-galvanizing/http://www.galvanizeit.org/specifica...ring-hdg-steelhttp://www.harrisproductsgroup.com/e...s/Gal-Viz.aspxhttp://www.amazon.com/Galvanizing-Re.../dp/B001QUZ94A"USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:Thanks....That's exactly what I was looking for.
Reply:Originally Posted by Oldendumhttp://www.galvaguard.com/hot-stick-galvanizing/http://www.galvanizeit.org/specifica...ring-hdg-steelhttp://www.harrisproductsgroup.com/e...s/Gal-Viz.aspxhttp://www.amazon.com/Galvanizing-Re.../dp/B001QUZ94A
Reply:Fabricators can fill holes up to 3/8″ reliably using Galva-Guard.
Reply:I saw some hot galvanizing (zinc) rods in the solder/braze area at my LWS the other day.  Thinking about getting some to try out for repairs to zinc plated stuff.KevKevin / Machine_Punk from The Aerodrome Studio - Lincoln PowerMIG 210 MP - Meco N Midget w/custom welding station - Vintage Victor 100Current Projects: The Aerodrome Studio
Reply:Originally Posted by Machine_PunkI saw some hot galvanizing (zinc) rods in the solder/braze area at my LWS the other day.  Thinking about getting some to try out for repairs to zinc plated stuff.Kev
GMT+8, 2025-12-31 13:05 , Processed in 0.265740 second(s), 18 queries .
