WTB Inverter assembly for Miller Pipe Pro 304
发表于 2021-8-31 22:30:59 | 显示全部楼层 |阅读模式
I just bought a Miller pipe pro 304 that only has 350 hours on it and the Kubota diesel runs great,but it is missing the inverter.The guy I bought it from, bought it mounted on a dodge dually from a municipality,and just wanted the truck to put a dump body on it,and had no use for the welder. He did not know the history of it or why the inverter assembly was removed,if it went bad,or was stolen etc.If anyone has an inverter for this ,or knows of one let me know.You can email me [email protected]        JimMiller Bobcat 225 NTSpoolmatic 30AMillermatic135Snap on MM140Snap on ya212iaSnap on spool gunCutmaster 51 L-TEC plasma cutter
Reply:here is an XMT 304 being sold as parts,maybe it has what you need?http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWAX:ITIf not talk to Larry (weldersales)Aaron
Reply:Thanks for the heads up Aaron.                                                              JimMiller Bobcat 225 NTSpoolmatic 30AMillermatic135Snap on MM140Snap on ya212iaSnap on spool gunCutmaster 51 L-TEC plasma cutter
Reply:Double PostLast edited by Roadtech; 09-19-2010 at 11:22 AM.
GMT+8, 2025-12-31 13:05 , Processed in 0.191920 second(s), 18 queries .
