40 cu ft Argon bottle (full)
发表于 2021-8-31 22:30:57 | 显示全部楼层 |阅读模式
I have a 40 cu ft Argon bottle from my TIG welder. I purchased a 330 cu ft for home use and I doubt I'll have much use for this one. I had it filled by my local shop the same day I purchased my 330, so it's completely full and I believe the hydrostat date is 2006 on it (though I'd have to check, I know it's still current and has some time left on it).Local pick up only.trackbird (at) gmail dot comKevinHobart Handler 210Tweco Fabricator 181iLincoln Squarewave Tig 175
Reply:Are we on the "Price is Right" and we are supposed to guess the price on the cylinder?  I'd like to start with a bid of $10 Bob...  ( Just kidding)A 40cf of argon is a bit small for most tig machines unless it's portable, but it would make a nice cyl for a small portable mig. The cyl should swap easily for C25 at any welding supply if you didn't have a need to do alum with the 100% argon..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Oops, I thought I put the price in there when I typed that up, but apparently I didn't. Sorry (and thanks!).Asking $95 obo and I'm located in Columbus, OH.KevinHobart Handler 210Tweco Fabricator 181iLincoln Squarewave Tig 175
Reply:dang 95$ i picked up 155cu bottles for 60$ a piece at a bank auction
Reply:Kevin,What CGA fitting is on the bottle you're selling? If it's the standard fitting, the same as full size cylinder, I'll  take it off your hands for $60...I'm about 60-90 minutes west of columbus.Benson's Mobile Welding - Dayton, OH metro area - AWS Certified Welding Inspector
Reply:That should be a standard CGA 580 inert gas fitting same as the bigger cyl's. The number should be clearly marked on the valve itself..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
GMT+8, 2025-12-31 13:19 , Processed in 0.101222 second(s), 18 queries .
