I am going to sell the 1917 12 x 5 Hendey tiebar lathe that I inherited from my dad. I just brought it to my place in August but I am cramped for space and already have 2 other good lathes. I have only run this lathe a couple of times but everything seems to be in good working order. It has a 1-1/2 HP single phase motor and a 4 speed transmission/gear reducer. There is only one thing that may need adjusted, the spindle seems a hair tight but it spins fine under power. It just doesn't "free wheel" when you spin it by hand. I have never fooled with adjusting the Hendey bearing design and I would think it could be loosened up if desired. Dad ran it this way for over 20 years. It comes with 3 and 4 jaw chucks. $750. Call Bill 412 496-0619 cell Hendey 12 Inch Engine Lathe Backgear Ratio 10.4-1 Countershaft Pulleys 12 x 3-1/4 Cone Diameters 2-5/8, 4-1/4 5-7/8, 7-1/2 Carriage Bearing on Bed 16-5/8 Belt Width 1-3/4 Swing Over Carriage 7 Spindle Nose Dia. - Pitch 2- 8 TPI Swing Over Bed 12-5/8 Hole Through Spindle 13/16 Lead Screw Dia. Pitch 1 6 TPI Tailstock Spindle Dia. 2-21/32 Cuts Screws, per inch 1-1/2 - 80 Centers - Morse No. 3 Range of Feeds, per inch 6 - 320 Center - Bushing No. 4 Size of Tool ½ x ¾ Compound Rest Travel 3 Cross Feed Screw Graduation .001 Capacity of Center Rest 3-1/2 Front Spindle Bearing Taper Diameter 1-7/8 to 2-3/8 x 3-11/16 Long Rear Spindle Bearing Taper Diameter 1-15/16 to 2-3/16 x 2-7/8 Long Weight - Lathe 5 bed 1680 lbs. Attached Images
Reply:A great Lathe, Zap runs one from the 40's everyday. If I was closer it would be sold.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Originally Posted by TozziWeldingA great Lathe, Zap runs one from the 40's everyday. If I was closer it would be sold.
Reply:The transmission has 4 speeds plus the 10.4-1 backgear, so you have 8 speeds on each step of the cone. 4 steps so you have a total of 32 speeds. I never counted the rpm's but it will crawl. I have only run it n the slowest step.More info:http://www.practicalmachinist.com/vb...y-home-209592/Last edited by WFM; 09-25-2010 at 08:48 AM. |
