Pulser for Dialarc..
发表于 2021-8-31 22:30:56 | 显示全部楼层 |阅读模式
Is it possible to buy a pulser unit and set it up for a Dialarc 250HF? Just curious if it is worthwhile and possible, as there are many benefits to being able to manipulate the pulse and frequency along with balance for AC/DC TIG welding.1973 Lincoln SA 200, Already replaced shunt coils, Idle board (SOLD)1984 Miller Dialarc 250HF, Miller water cooler, 250 AMP water cooled torch, you know the worx.
Reply:Thanks again for the help Steve.1973 Lincoln SA 200, Already replaced shunt coils, Idle board (SOLD)1984 Miller Dialarc 250HF, Miller water cooler, 250 AMP water cooled torch, you know the worx.
Reply:Funny you should mention this.  My 16 year old son is in a digital electronics class and we were talking over practical projects to aid his learning.The two projects we came up with were an upslope/downslope rig to use with a torch switch and eventually figuring out a pulser.These would be for my Airco (miller ab/p) and for my regular Dialarc with a spark box. May not be till summer but it should be interesting. Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:For the electronics - maybe use something like an arduino?http://www.arduino.cc/Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Nice, Dave!!1973 Lincoln SA 200, Already replaced shunt coils, Idle board (SOLD)1984 Miller Dialarc 250HF, Miller water cooler, 250 AMP water cooled torch, you know the worx.
Reply:He's leaning towards electronics/computers/engineer as a career choice so I figured get him in working on stuff for real as early as possible so he gets hooked - like he is on TIG already  Plus, as a learning/teaching philosophy, I believe education should be tied to real life as often as possible Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
GMT+8, 2025-12-31 13:15 , Processed in 0.080613 second(s), 18 queries .
