Homemade Hossfeld die
发表于 2021-8-31 22:30:48 | 显示全部楼层 |阅读模式
1"x3.5" radius..25" plate for sidewalls plug welded to solid round inner.Inner radii formed with Loctite Steel Putty.Works ok. Only problem is you gotta beat the material out of the die when done.The first bend is what happens when the tubing doesn't roll with the die.No special follower or wiper dies.Pics to follow since tapatalk is messing with me again.....Lincoln SA 200Esab Caddy 160Thermal Arc 201TSMiller Dialarc HFI don't like making plans for the day because then the word "premeditated" gets thrown around the courtroom....
Reply:Sent from my XT907 using TapatalkLincoln SA 200Esab Caddy 160Thermal Arc 201TSMiller Dialarc HFI don't like making plans for the day because then the word "premeditated" gets thrown around the courtroom....
Reply:Nice build,what is the JD side screens off from ?
Reply:Originally Posted by gamehoggr1Nice build,what is the JD side screens off from ?
GMT+8, 2025-12-31 13:13 , Processed in 0.391727 second(s), 18 queries .
