Water Heater Stand Part 1
发表于 2021-8-31 22:30:47 | 显示全部楼层 |阅读模式
Building a water heater stand for a client....I rushed the weld on the little 110 hobart...oh wellThanks for watching!!
Reply:Great job!   If your still able to so so, I would add a diagonal brace from the bottom foot of two opposing legs, up to the base of the box frame.  A "diagonal" brace adds much needed stability to a heavy platform such as yours.  Actually an "X" shaped crossmember is the best, but a single diagonal on two opposing legs should suffice.Lincoln Power Mig 216Lincoln AC/DC-225/125Miller  625 X-Treme PlasmaMiller 211 Forney 95FI-A 301HF 91110Victor Journeyman O/PMilwaukee DaytonMakita  Baileigh NRA Life Member
Reply:okay..will do!
Reply:Safety glasses?     I hope this isnt going in a garageVantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:nice quickie job. thumbs up!i.u.o.e. # 15queens, ny and sunny fla
Reply:What kind of saw is that?Sent from my iPhone using TapatalkLincoln Pro Mig 180HF Stick/Tig Inverter WelderLincoln AC225s
Reply:The saw is a 70.00 cheapie fro Harbor Freight...I bought one and a week later it broke so I returned it..it is good for small cuts.....thanksSent from my iPhone using Tapatalk[/QUOTE]
GMT+8, 2025-12-31 11:41 , Processed in 0.099154 second(s), 18 queries .
