查看: 2|回复: 0
Miller auto darkening goggles
发表于 2021-8-31 22:30:45 | 显示全部楼层 |阅读模式
Has anybody tried these yet?http://www.millerwelds.com/products/...uto-darkening/Sent from my SPH-L710T using Tapatalk
Reply:I haven't used these, but I have figured out a much cheaper equivalent for when I'm in a tight spot. I put my Arcone 240 drop in auto dark lens in a pair of 2x4 gas welding goggles. Cover your face with a ski mask or bandana. The bonus to this is that you can use the lens in a regular hood too. I think I paid $55 for mine and the goggles came free with a torch setup.
Reply:Or skip the mask/bandana and use miltary sunscreen.......honest, I heard someone say that one day.They look like they would be a PITA to put on.
Reply:I have these at work for getting into tight spaces. The company I work for purchased these for me. They work ok if you don't need to wear glasses to see and have a good tolerance for heat as you get pretty warm and sometimes fog up.
Reply:I want some so bad for pipe rack tie ins~1987 Lincoln Sa-200~~1978 Miller Big 40~ (restored) ~and everything inbetween~
Reply:I have one of these...http://www.ukwelder.com/shop2/shop_i...e=monkey_masksRich
Reply:According to Fedex, mine (Miller Weld-Mask) should be here tomorrow.  Ordered it from Cyberweld.  I've been having a hard time with glare, even after making a bib for my helmet and draping the back of it with heavy denim.  So I'm looking forward to getting a really good look at what I'm doing.
Reply:http://www.ebay.com/itm/371140046410...%3AMEBIDX%3AITBacked my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:Looks like they'd be miserable in hot weather.-RuarkLincoln 3200HDHobart Stickmate LX235TWECO Fabricator 211i
Reply:Got'em.  Just tried them for the first time, and I have to say wow.  I can finally see what I'm doing.  I have a Miller auto-darkening helmet, which is fine, but I'm always getting so much glare that it's hard to focus on the weld.  The Miller Weld-Mask shuts out the outside light.  For a newcomer like me, that's tremendous.  Hot? yeah, but not really any worse than a regular helmet with heavy fabric attached to the front and back to try to block out the glare.  That makes kind of a mini-tent that also collects heat and smoke.  Here's a pic of some practice beads that I just did:Now, you're saying to yourself, OK, that looks pretty ordinary, but for me it's a great leap.  That's 1/8 6013 at about 130-135 amps dcep, several beads thick.  I've had a hard time running beads straight, and now I can see where I'm going.  I'm sort of a beginning hobbyist, although I have made the last 4 backflow cages for backflow devices that I've installed (I'm a plumber).
Reply:Originally Posted by killdozerd11http://www.ebay.com/itm/371140046410...%3AMEBIDX%3AIT
Reply:That would be me ...The Unknown WeldorI use them when doing mig and fab work  .They are shade 3 when turned down to use the plasma and grind..It lets you see better than shade 5 most autodarks default toGreat for doing the hold and tack fab up work but it has a drawback when you bend down it comes away from your face so have to tuck it in your shirt or leathers Backed my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:I have to thank Killdozer, I got my Weldcap yesterday and couldn't be happier with it.   The cap is comfortable to wear and the sight picture is great.   In the light setting you can easily do bench work even in dim areas.     This is one of if not the most comfortable hoods I have worn.    It was in the mid 90's when I used it, a bit warmer than a regular hood but not uncomfortable like the Miller shroud would be.Steve from SoCal now in HutchMiller Dynasty 300DX Coolmate3 Speedway TorchMiller XMT 450 MPa plus with D-74 MPa Plus Miller Bobcat 225 NTHypertherm Powermax 45And a whole bunch of machines
Reply:Thanks  and glad you like it ...Optrel has always had really good optics and it's really nice when plasma cuttingOne more thing to like is that you can take it off and hang it on your belt with one handBacked my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
GMT+8, 2025-12-31 15:10 , Processed in 0.073430 second(s), 18 queries .
