Ace Mobile Welding Fume Extractor
发表于 2021-8-31 22:30:41 | 显示全部楼层 |阅读模式
This is a brand new Ace Mobile Welding Fume Extractor. Model number 73-601 -1200 cfm, high volume fume extraction and filtration capacity -Designed for shopfloor use with the mobility to move from workstation to workstation -10 foot extraction arm with articulated joints designed to hold position for hands-free use -Units accomodates 18 different filtering combinations for maximum flexibility in all types of applications -Wide mouth source capture hood -Heavy duty steel construction -Built in spark trap for fire safety -Durable caster, two that swivel and lock for stability -Filter status gauge -Built in AC outlet to power tools and accessories -UL Listed -Made in USA -Dimensions: 52"L x 29"H x 26"W -Weight: 315 lbs. Its located in the Bay Area. If you have anymore questions feel free to call me a 415-307-7911. Thanks
Reply:Price???Is it being supplied with filters? If so what ones?Ken
Reply:Hey sorry for such a late response. It comes with whatever filters come stock with it along with 2 Hepa filters and 2 charcoal filters. Also comes with 2 extra hose extensions. I was asking 2500 but will consider any reasonable offer. Let me know if you have any other questions. Thanks
Reply:Price reduced to $2000
GMT+8, 2025-12-31 16:56 , Processed in 0.101712 second(s), 18 queries .
